Results 1 to 4 of 4
Thread: Steaming Light on Mast
    Mar 2003
    Boston
    Does anyone know how it is wired in the mast.
    I have an old deck plug that is going to be replaced it has five wires
    in one wire deal. Why would you have five wire connectors need some
    insight on this. I did not see any inlets or outlets on the mast. Where
    should I look?
    John
    What's the boat's number? Early models had the steaming light wire exiting from the side of the mast and into the cabin through a deck fitting. Later models had a tube inside the mast step through which the wire passed into the cabin. Some boats also have their coax cable for the VHF antenna exiting from the side of the mast and then into a seperate deck fitting.
    Mar 2003
    Boston
    It's 1962 first year of production. The deck fitting is just on the V-berth starboard side of the bulkhead. I didn't see anything on the mast.
    Where should I look.
    John
    Exclamation Search First
    John,
    A little searching of the posts in the "Photo Gallery" forum turned up several photos showing the wire exiting the mast. Take a look:
    #6 at http://www.pearsonariel.org/discussi...read.php?t=526
    #12 at http://www.pearsonariel.org/discussi...read.php?t=433
    #4 at http://www.pearsonariel.org/discussi...read.php?t=522
    #7 at http://www.pearsonariel.org/discussi...read.php?t=502
