C.P. ,
I've seen the gooseneck end fitting on the Rig-Rite web site. In fact it was then that I found out that the boom on my ariel was in fact a furling type. They have the center eye which in fact is just a spring loaded post affair replaceble on its own or I believe they have the whole gooseneck end fitting as well as the saddle. In fact I think they have the right size boom extrusion too.
My "eye" was worn nearly clean through and the saddle was also badly worn. A friend welded up the hole in the eye which I then redrilled to proper dimension and I milled out a new saddle from a piece of scrap aluminum which I had pack-ratted away for 23 years!!! Pack-Rats rule!!
Good luck getting the end fitting out of the boom.
Russ
