Page 15 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 211 to 225 of 250
Thread: Outboard Discussions
  1. #211
    Wiring diagram for an O/B
    Sometimes I spend a frustrating hour at breakfast looking on google for auxiliary sailboat electrical schematics.
    It's amazing how difficult it is for a dummie to find something useful.
    Here is an exchange between a boat builder (LP - Senior Member) who knows at the start more than I will ever know about electrical systems - and begins with a nice clear colorful diagram. With input from others he updates the diagram as help arrives.
    In his opening post he says he'd 'like to put it in the electrical WIKI of
    boatdesign.net
    for the benefit of others.'
    This 8 page thread is worth a visit. The schematics are in full page color and downloadable.
    A338 is an OB Ariel, thus I find this basic short course in planning the wiring extremely usefull. What makes it unique is the progression of the diagrams.
    What do you think?
  2. #212
    Ebb
    Do you have a link to the thread?
  3. #213
    diagrams address
    Well the address had one of those long specific thingies that in the past just don't seem to work.
    So I just assume that googling will get you there, tho not instantly:
    google> Wiring diagram for an O/B - Boat Design Forums
    http://www.boatdesign.net/forums/ele...o-b-26855.html
    [ EDIT: whaduyouno - it works!!!!!!!]
  4. #214
    Thanks Ebb I will study it in detail tonight.
  5. #215
    Not Specific to OB, sorry
    testing access diagram
    http://suter.tripod.com/wiring/wiring.jpg
    Have to get it by Google> Pearson Triton Wiring Diagram
    From the 80's with upgrades. For a Triton with a lot of support for an inboard.
    I really liked the emphasis of the thread from boatdesign.net on the OB because that is my interest.
    But I like best the changes others suggested that influenced and altered the plan and made it better - so far as I know.
    Imagine a basic diagram aimed specifically at the Commander/Ariel sailboat.
    BASICS
    Starter battary
    Deep Cycle Battery
    Battery siwtch
    Battery isolator
    Outboard Starter
    External Lights
    Cabin Lights
    Fuses/Circuit breakers
    Single Pole switch
    Cabin LED aft, fore, dome/blkhd, V-berth
    Masthead light
    Steaming
    Flood
    Port, Starboard, Stern lights.
    Bilge pumps/Blower
    12V inverter to 120V
    120V shore power
    120V receptacle
    MORES
    Battery charger
    DC panel
    Compass light
    Fish finder/depth sounder
    Knot meter/log
    Engle fridge/builtin
    Shower pump
    Fresh water pump
    ELECTRONICS
    OB gauges, oil pressure, ammeter, voltmeter, fuel, temp. tach, starter-ignition switch.
    EXTRAS
    Air conditioner
    Stereo, TV
    Water maker.
    Hot water
    Lightning ground conductors. (Totally separate system)
    Solar panels
    Charge controller
    Digital battery moniter.
    Alright, how we do dis?
  6. #216
    Ebb, that is what i'm trying to do now...
    But being that Destiny is going to be an electric drive it will be unlike most Ariels and Commanders out there. My system will have one very large battery bank that outputs 48VDC and a DC/DC inverter that will step the 48V main system down to 12V for the house electric. In addition I will have a seperate 120VAC system that will be available for use when hooked up to shore power.
  7. #217
    A plan for wiring an A/C with a gas OB
    I've found a good exchange on an ericsonyachts.com site from late last year (current) that looks like a good lead in for litlgull.
    The guy gets good advise from the likes of Maine Sail and others on grounding, integrating a simple AC into the mix*, charging, dedicating battery 'banks', and whether he should include an ACR or not.
    Seems like a good place for me to make a good start on........ THE PLAN.
    Important in this thread is that the progression of the discussion yields a progression of versions of the plan in diagrams with colored wire. Which helps understand how wires are chosen, and where they end. Discover for the first time that the DC ground on an OB boat is the battery negative terminal, not the OB or a bronze plate attached to the hull somewhere (that I fantasized.) It's a place to start.
    Also found a Basic Electricity manual on New Boat Builders Home Page that is easy to read, well written, not patronizing, well supported with links and advice. The writer should be thanked with a name - and toasted,
    which will happen if this post lights up and becomes a thread in its own right.
    __________________________________________________ __________________________________________________ __________
    *....and I quote Maine Sail
    "AC White/Neutral goes back to shore through the shore power cable.
    AC Green/Ground does not go back through the shore power cable. once on the boat, and is grounded on board the boat. In this case to a neg buss bar which is connected to the battery neg terminal or directly to the battery's neg terminal because this is an 'ungrounded' DC system at this point."
    there you go, a demo of the dunno, and why I needs a plan.
  8. #218
    ebb
    I found a pretty good book on boat electrical systems. It's called Boatowner's Illustrated Electrical Handbook. written by Charlie Wing. Charlie writes in a manner that makes a rather complicated subject pretty easy to understand. I don't read many techincal books cover to cover but this one I probably will. I recommend it.
  9. #219
    Sep 2006
    NY
    Nissan 4 Stroke Outboard Running the Gas Dry
    I have the standard Nissan 6HP 4 stroke outboard. What I have been doing after each use is to pull out the gas line and running the gas dry. I use the outboard just to get in and out of the dock and it would not be unusual for the boat to sit for 2 weeks with no activity.
    Is this the right thing to do or should I just shut the motor off and leave the gas line connected?
  10. #220
    Nov 2009
    Brooklyn, NY
    jshisha
    I think it's OK to run the motor dry, although likely unnecessary, it's not going to hurt anything. Many aircraft motors are shut down by cutting the fuel supply.
    Ben
  11. #221
    Apr 2008
    Forsyth GA
    I would concur that running the system dry is best. Especially with Ethanol tainted fuel, when the engine will not be used for 14 days.
  12. #222
    Nov 2002
    Outboard Motor Strategy
    I have a Johnson Seahorse 6hp motor which I remove from the well every time I leave the boat on its mooring. I'm tiring of the time and effort involved in the mount/dismount routine. Most of my sailing lately has been to take guests out. The delay is taking the fun out of the trip. Others in the Chesapeake area are warning me that leaving the motor in the water will result in the water intake becoming clogged and the motor overheating.
    I'd appreciate descriptions of other solutions that are working for Ariel/Commander owners whose boats are in warm brackish water such as the Chesapeake. How close to inboard functionality can I get without risking engine damage? If I see a system that leaves the motor in the water for the entire season and has electric start I'll buy it. Otherwise I'm considering selling this boat and looking for something with an inboard.
    Photos help. I think in pictures.
    Thanks.
  13. #223
    Jul 2011
    Annapolis, MD
    Eh, I don't know about the intake becoming clogged. I had, over the summer, a Sea Sprite 23 with a 5hp Evinrude (REAL old one) and I would routinely leave it for a month or so when I was moving it up the Hudson and through the Erie Canal. I never had a problem with overheating until I screwed up the oil mixture and toasted the engine. It's amazing how fast that can happen! I left the boat for six weeks in brackish water in Newburgh, NY and when I came back to it, the thing started right up and chugged along for another 200 or so miles. I did have to clean the prop and lower unit but the intake wasn't clogged and she pumped water fine. It's possible that you might get more growth in the Chesapeake but the conditions seem similar to me. I dunno, I'd definitely get more opinions before you sell the boat. And certainly don't take mine as the gospel truth!
    Out of curiosity, do you own an Ariel or a Commander? I know there was an Ariel in the DC area with a Seahorse Outboard that was for sale last spring. Red hull. Is she now yours?
  14. #224
    Nov 2002
    It's a Commander.
    Sep 2006
    NY
    Single Lever Throttle Controls 6HP Nissan
    I have the standard 4 stroke 6HP Nissan Mercury outboard. I would like to mount a single lever engine throttle / control in the cockpit, but the standard controls are very plastic / modern looking and it would be like painting a mustache on the Mona Lisa. Does anyone know of any classic looking chrome or bronze single lever controls that would work. I am in a tight slip and it would be very helpful to have the controls
    Thanks
    Jake
  1. Outboard Well
