Results 1 to 15 of 53
Thread: Photo gallery of ariel #74 restoration
Threaded View
  1. #11
    The Cunningham Assumption
    You guys is correct I think. Just had a ride on a Triton that still had an adjustable gooseneck AND a cunningham rigged. It's main purpose seems to be to tighten up the luff - because you didn't get it tight enough with the halyard. I'm sure there is more finesse to this then that.
    Little Gull, which I bought not knowing, came with a fixed gooseneck on what looked the original boom. Had already been modernized - if that is the term. If a boomvang is fitted you can't have an adjustable gooseneck.
    On 338 there was a fairlead type eye on the deck between the mast pad and the dog-house rise. A decommissioning photo shows it to be an insignificant piece of gear - and if I remember, it had no back-up plate inside. Didn't look serious at all.
    What is the skinny on this?
    __________________________________________________ ___________________________________________
    Just discovered that a Cunningham is a grommet in the luff of a mainsail with a FIXED GOOSENECK used to tighten the luff.
    Would assume you wouldn't need to go to the deck to tighten the luff but just to the fixed boom or gooseneck.
    A sliding gooseneck is original to a roller-reefed main so that the end of the boom could be adjusted up when reefed. So said on a Brion Toss page, But I may have misinterpreted. Again.
    Did Ariel's and Commander's have roller reef booms originally? Maybe an option?
    But a tight luff can be achieved with a boom downhaul to a block at the foot of the mast - no cunningham - if the boom has a sliding gooseneck. Kind of a which came first: the goose or the egg???
