Ebb: "Showing the end on the new toerail and a transom begging for a taffrail!"
Ebb: "Curtains and runs from a disastrous spray-on primer fiasco. Expectations were of a thin easy to sand final prime. Even paid the guy for his time. And yours truly spent the hottest days on record in San Rafael longboarding and sanding the damn stuff nearly all off!"
Ebb: "Port scuppers cut into the molded rail under the new toerail just forward of the Pearson deck scupper. Whether this is the place for them is arguable. They are also near the winch base and will constrict water flow on its way aft. It is way more traditional to have scuppers evenly spaced along the bulwark."
Ebb: "Portrait of the port side toerail"
Ebb: "Finally the OB motor well gets its primer coat, albeit lots of runs, but relatively easy to sand. Wish I could get somebody else to do it!"
Ebb: "This shows the dodger from the cockpit. The piece is made from xmat and epoxy over a form. 1/2-inch pvc foam was bent and glued to that and more xmat on top. Classic sandwich. Works in progress have many unknowns and surprises. How it will actually finish up can't tell (ideas, anyone?) - or even if it will have a place there aesthetically. Unlike Geoff, who has the area covered, the dodger proposed here is only a windscreen requiring an expensive pipe and canvas pram hood to fully protect the c'way. Dodger has its own bridge over the c'way making it independent of the seahood. There's a choice whether it will be permanently installed or made removable. Picture shows the big side hatch-slide rails now built in. They run the length of the cabin top and the seahood (also removable) mounts there on. Note taller coamings extending up from the inside and the mockup of a flat hatch."
Ebb: "This shot shows the seahood made with the original sliding hatch. There may be room under the forward part for a dorade. Dodger shows some off-the-wall possible windows. I had planned 3/8" carbonate for these - but bending the plastic to those curves is totally daunting. Center window indicates a Taylor-Made opening hatch."
