Page 9 of 17 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 LastLast
Results 121 to 135 of 250
Thread: Outboard Discussions
  1. #121
    Jul 2006
    Outboard Shaft Length
    What is best 15" or 20" or 25"?
  2. #122
    20" fits the boat and keeps the prop in the water.
  3. #123
    Wink
    Bump
    Bump
  4. #124
    Nov 2001
    The deeper the shaft, and hence the exhaust, the more important it becomes to vent the exhause relief outlets obove the wate line. The deeper shaft increases the back pressure throught the exhaust outlet in the lower unit, particularly when the motor is idling or at low speeds. This will therefore increase the amount of exhaust that exits via the pressure relief holes (so there is no back pressure, regardless of the level of the lower unit exhaust outlet). When operating at higher speeds the through prop exhaust sucks the exhaust out (or is designed to do so - but perhaps not completely) A prop/exhaust that is one foot lower than a shorter version increases the back pressure by 62 lbs/inch.
    But still I would opt for a longer prop shaft -and in no case take a standard length because it pops out of the water - in my experience. Other than as mentioned above, I don't see any disadvantage to as long a shaft as you can get.
  5. #125
    Jul 2006
    The ultra long shaft(25") that I am considering comes standard with Alternator, which is a plus.
  6. #126
    According to motor people ,those that fix them and sell them, if your transom is 15" off the water then get a 15 , 20 a 20 and 25 a 25 . They say it is not good to put a 25" shaft on a 15" transom . A 20 comes closest to fitting these boats .
    Not my words , my mechanic's .
  7. #127
    Nov 2001
    Ordinarily, I would listen to the OB fixit people, and have done so until some recent inquiries regarding the OB and the Ariel. When the answers are randomlly different, and border on "I don't know but my best guess is.....", then your own best judgement is my recommendation. For example, I no longer take the advice of the OB fixit types with regard for fuel mix. With the Yamaha, it is ONLY 100:1, not 75:1 or 50:1 as most OB types I have contacted have suggested - their reasoning being that a bit more oil is erring on the safe side. The richer oil alternatives do not work.
    The problem with the OB fixit types (and generally the manufacturers as well) is that they are generally not familiar with the unique circumstances of powering a sailboat with the motor in an inboard well. Their recommendations for shaft length are based on a conventional boat, and perhaps even a conventional non-planing hull. These boats do not have the problem with cavitation at the lengths they recommend, do not have a keel extending far below the drive shaft, nor do they go out in heavy seas, nor are they asked to run when the boat is heeling at 20 to 30 degrees. In short, the information upon which they base their recommendation is notoriously incomplete.
    Summarizing, I would recommend ignoring the OB fixit types and going with the insight of those that have OBs driving the Ariel - which in today's world, is a unique OB driven design. The caveat, however, is if you make it the drive unit lower in the water, the back pressure is greater than the OB design back pressure, and the amount of exhaust exiting the pressure relief ports will be greater. This exhaust must be exited to the outside world (not just the motor well). This may not be mandatory with a shallow draft motor.
  8. #128
    May 2004
    Pembroke Ontario Canada
    This 'simple' question is getting WAY too complicated for a basic mind like mine. IMHO...I had a 20" shaft and found that even motoring into waves that at times were quite large...I experienced only VERY minimal cavitation. 20" is fine in my books...it works!!
  9. #129
    Nov 2001
    Back to basics. Yesterday I took the critical measurement. I have 15-16 inches from the water surface to the center of the prop. My engine has cavitated a couple times in high seas. If I had a preference, I would put it in the 17-19 inch range.
  10. #130
    Quote Originally Posted by Mike Goodwin
    Add another vote for 20" from me.
    The longer shafts (9.9 merc long shaft, and johnson 8) I have seen on Ariels don't 'bite' any better then mine, and my 20" Yamaha 6 has never come out of the water on me.
    I agree with Peter, in that I might not go with a 15" shaft for fear it would not stay below the surface.
    The old Suzuki 8 that I had was a couple inches shorter(17"?), and it never came out, but would get close enough to cavitate in a bad chop (but still useable). I would not use a short shaft on an outboard if it were going to hang on a bracket mount or a transom (like the P-26) since they tend to pop out of the water more then the 'outboard in the well' like we have.
    I am sure that with a 25" shaft, the prop gets 'cleaner' water deeper, but it also produces more drag there when sailing. Having motored Ariel's with both, I prefer a 20" shaft, and will probably re-power with the same. (and will not go over 8 hp FWIW).
  11. #131
    Dec 2005
    Tampa, FL
    Merc 2
    6 HP Merc 2 on mine, if I had the dosh I would go for a four, but a two is cheaper. Would not go less than 6. BTW, I strapped a 15 on the back a couple months ago, just to see if you could tow a skier, you can't.
  12. #132
    Dec 2005
    Tampa, FL
    A thread from the dead...bump indeed.
    I was just thinking the opposite as I dangle mine (20")off the back and can almost bury it if I want. Middle position on my Garelick mount keeps it buried most of the time, plus I can turn on a dime with it off the back.
    Quote Originally Posted by c_amos
  13. #133
    Quote Originally Posted by Howard
    A thread from the dead...bump indeed. I was just thinking the opposite as I dangle mine (20")off the back and can almost bury it if I want.
    The management frowns on stern mounted outboards. Very dangerous in rough seas as was documented by the experience of a Bay Area skipper. Discussion is in another ob thread . . .
  14. #134
    Dec 2005
    Tampa, FL
    Quote Originally Posted by Bill
    Oy --- it's a sailboat after all innit it?!
  15. #135
    Dec 2002
    Conshohocken, PA
    New Nissan
    The 2006 Nissan 6 hp four stroke outboard comes with a 25 inch shaft and an alternator.
  1. Outboard Well
