Results 1 to 15 of 49
Thread: deck scuppers
    Nov 2001
    Anyone have this problem with what I assume was factory issue (#82)? This Ariel has a break between the taffrail rail and toe rail, but in the slot at the aftmost part of the break, at the edge of the transom, the slot where the water should flow our freely, curls up and blocks free egress of a portion of the captured water. Was this a manufacturing mistake, or do others have a similar curl?
    Peter -
    I think that was/is supposed to act as a sort of a "dam" to encourage water to go down the small holes and into a water-gathering system in the lazarette, or maybe under the cockpit. This is what Craig was referring to.
    At least that is my interpretation of what that "curl" is for... 8^)
    stern scuppers
    The mini ramps also provides a back for the s.s. 1/2 round 'rubbing strake'. Or it did on 338.
    Popped out the wedgies and faired the slot down to deck level with 1/2 round files - this takes it down further than the deck/hull seam. You'll be opening the seam when you do this.
    The factory seam inside the laz is battered with poly and matt which you may expose. Just open and clean out the loose stuff there on top and fill with epoxy filler, file and fair, paint or gelcoat. Then cut the 1/2 round trim shorter to fit if necessary.
    The only downside might be staining on the transom under the openings from water now able to run off the stern.
    You can sorta see this lowering of the scuppers in the Gallery on pages 13 #166 and 14 #198.
    I've found that "ramp" provides a means to propel the running water far away from the stern, so water staining is no issue...
    Yes, a new boot stripe is in my future - after some other issues are addressed.
    *****en stain pain
    Nice boat there!
    Boot stripe problem might be fixed by stationing someone of equal weight in the bow.
    The little ramps in the scuppers have caused puddling in the deck aft of the thru-deck scupper next to the coamings.
    If you keep the edge sharp there where water exits (when you take the wedges out) it is less likely to dribble down the transom. It's boats that sit around collecting dust that have a stain problem.
    Here's a pic of what Ebb's talking about methinks - a shot of where the water exits at the stern...
    As seen in post #41 above, my boat has no issues draining the water aft-wise from the decks, and the factory scuppers work fine (scupper to port of the cockpit below). After I remove the lead pig or whatever it is from bowels of my bilge (discussed in another thread), I'll see how the draining works this next season.
    On a "fix one thing, break another" note, I do however need to add some cockpit drains to the aft end of the cockpit, so the water will drain there instead of pouring down my cockpit hatch. Turns out it's not so water-tight when submerged...
    By Theis in forum Technical
  2. Deck hardware plan, and
    By c_amos in forum Technical
  3. All those wires inside my mast gotta go!
  4. Replies: 11
  5. The Deck 'Job'
    By Tony G in forum Technical
    Last Post: 10-14-2004, 06:44 PM
