Bill,
What a great job you have done! Your workmanship is top notch!
I just picked up that same Bomar hatch 2 weeks ago, when I find the 'round tuit' I will be looking for more info on exactly how you built up that mount.
Great boat!
Bill,
Great boat!
Originally Posted by mbd
I found the two part stern rail (new) in a consignment shop. The manufacturer's label read "High Seas" (never had any luck finding a web site that matched the label). The installation was probably easier than a single piece, the only mod was that I needed to shorten the aft most column.
The remains of the label for the stern rail show the following mfr address:
High Seas
4861 24th Avenue
Port Huron, MI 48060
313-385-4411
I like the two piece version, it doesn't get in the way when boarding over the stern (at the dock or by ladder when out of the water)
thanks for the kind words,
bill@ariel231![]()
You do some dazzling carpentry there, Bill. Thanks for sharing.
Teak rubrail.... that's real class. Great idea, nice work on that V-berth grate.
Gladdens the eye!
Compass cover does double duty for grog, correct?
Aye grog or gruel. depends on me mood....
Welcome, Bill 3
Verrry nice vessel you have there - top notch work - I was also wondering about the split pushpit she has.
periwinkle is wrapped up for a short hibernation. As time permits, this winters projects will include mounting the new port light frames... ...I'm starting to think about adding a radar mount sometime next year. Has anyone tried a removable stern rail mount? The building blocks in my garage are a 2.5" aluminum tube and some spinnaker car toggles...
A festive new year to all....
bill@ariel231
The snow is melting, the RedSox are playing baseball in Florida... humm.... must be time to get the boat cover off. It's time to install the new portlights (covered in the technical discussion under the "Large Portlights" thread http://www.pearsonariel.org/discussi...ead.php?t=1227 ), lifelines, zincs and bottom paint.
Here we are two days into the process....Just three weeks till launch.
I had a couple email requests for details on A-231's stern rail attached are some photos:
... and a dimensioned sketch if anyone is heading to a welding shop:
There have been a couple of threads on the site related to coaming repair. While I haven't had to deal with rotten wood, 40 years of abuse left A-231 with a couple of splits on the port side coaming. These were fixed with a couple of dutchmen replacing the splintered and torn sections.
As you can see, the color match isn't perfect but the original fabric of the boat is still in place
here is the repair to the torn screw hole on the forward edge:
the repair to the aft end of the coaming was needed where a split occured along the line of fastners. originally I just glued this with epoxy, but the coaming split again right next to the seam. In the end a whole section was cut out and a new piece glued on....
The technique is shown in the sketch below. I tend to use a circular saw to rough out the openings for new material. Other more careful folks use a router or chisel...
bill,
when 338's new coamings go in - and having seen so many coamings split at exactly this place - think I will drill in thru the bottom edge 3 or 4 holes to glue in dowels of the same material, mahogany in my case.
Think the split occurs from the upper portion of the coaming being free standing. Someone could design a nice curvey block that could be lagged into the deck and screwd to the coaming that would help keep it from bending outward. Wish I could add a drawing here!
__________________________________________________ ________________________________
Mysterious cleat and line going forward to the coaming post. What's happnin there?![]()
__________________________________________________ __________________________________
I'm also intrigued by the quarter rails with the stern wide open. What's happnin here? Are you berthed with stern access? Does look cool! Thanks for the cad and measures!
I noticed in the earlier post, that is his furling line. Pure genus! I love it.Mysterious cleat and line going forward to the coaming post. What's happnin there?![]()
Mine is strung outboard, with fairleads on the bow pulpit (like most bosts I have seen) and I regularly step on (read roll off of) the line when going forward.
Might borrow that one!
Add my voice to the choris of 'Great Job!'
OBTW, look how thick the glass is laid up under the keel in this shot.
Bill, thanks for the pics and the woodworking 101 drawings! Very helpful to those of us challenged in these matters...![]()
Why the SAME material? They'll be hidden, so couldn't you use some kind of indestructible wood or other material? Good idea, BTW, think I'll steal it.Originally Posted by ebb
Roller furling line?Originally Posted by ebb
Doh! I see Craig snuck his post in!
