What to try first? Play in the tiller.
I have a lot of play in my tiller (not sure if it is the tiller or rudder post or what).
I read through this post and I am not sure what would apply to me. I've attached pictures of my tiller head. What should I try first? Just tighten every bolt and see if that helps? (ignore the moisture meter from the survey).
Any help would be much appreciated.
thanks, Mike
