Stem Strap. Yes many boats have that. Would save weight if you're going with anchor roller/channels.Remember you have to incorporate another attachment point for the foot of the sail.
Another plate.
Bingham, (the Sailor's Sketchbook pg80/81) has idea drawings of stem and double anchor roller weld ups which might be very useful for a small cruiser. Something like that would slip over the Ariel nose.
And maybe even reuse the 8" bolt for the major attachment. That's the one that goes through the top hole in the original and exits through curve of the toerail/nose. Imco a VERY strong forestay attachment method.
If your Solent is coming from a lower position on the mast but to the stemhead fitting, don't you already have a third hole in the fitting that can be used for that?
