Results 1 to 15 of 348
Thread: Ariel #414
    Another shot from the first weekend back in the water. I don't think I'll ever get tired of looking at these boats!
    (Note: The mast is stepped, the water tank has been filled, and the lead pig relocated to the chain locker forward (67 lbs), and she's still not quite sitting on her lines... Oh well.)
    she looks about right to me (A-231 sits the same way with a 288lbs inboard and an aft mounted 12 Gal. fuel tank.). Is there anything in the aft most locker? Its a long moment arm from the CG of the boat. As a rule if I store anything more than a couple life jackets and a deck hose back there the boat squats a bit....
    one other question: Where are you batteries & fuel tank located?
    Bill
    I've only got my fenders and dock lines in the aft locker. The fuel tank is under the cockpit in front of the tiller post, which doesn't help. I think I recall reading in my Yanmar manual that the 2GM weighs in at around 225 lbs or so. (??) The batteries are at the forward end of the port cockpit locker. Those beasts are on my "someday" list to move forward. Also, I should still get some good ground tackle (chain) as Craig suggested previously.
    In any event, a topsides paint job is also on my "someday" list, and I'll fix the boot stripe then. By then, hopefully, I'll have had more chance to shift things around, though I am running out of options. Not that I'm complaining by any means. It's good to be sailing!
    So have you guys been out much in Periwinkle this season?
    The locations of your batteries and fuel tank match A-231. I've found that storing the sail bags forward in the vee berth helps with the trim too..
    been off the dock 3 or 4 times with our boat. we'll be on the edge of the tall ships parade this weekend if schedule permits... If it happens we'll post some pictures.
    May 2004
    Pembroke Ontario Canada
    Wink
    You are right..."never get tired looking at them" !!!!!!!!!!! Bonus is they sail great too
    Jul 2002
    Gorham, Maine
    By that time your boat load and trim should be fairly well established, so take lots of pictures and paint the boat the way she really sits--regardless of how that compares to the "design" waterline.
    Dasein's actual waterline doesn't quite match up with the scribed line either.
    Nathan
    Dasein, Triton 668
    www.dasein668.com
    I think it is probably a good idea to mark on the stem and stern where the designed scribed bottom line is/was - for future reference. This could be done with #6 - 1/2" roundhead bronze wood screws.
    No matter how much paint gets on them there'll aways be a bump to remind you - and to trim to if necessary.
    Woo hoo!
    Wow, was it a great day today!
    ...really great!
    Dec 2006
    Massachusetts
    It's floating art. She looks great! I really like how the name came out, nice and simple with a perfect arch (or elipse, can't tell from that angle) Enjoy!
  3. Ariel #382
    By Tim61N in forum Gallery
  5. What would you do?
