Nissan 6
Having had the Nissan 6 hp on my Commander, I would recommend the long shaft. With the 20" short shaft you'll experience some caviation in a steep choppy seas - the very conditions in which you'll least appreciate the cavitation. You'll amortize the incremental cost of the long shaft over the very long service life of the Nissan 6 and be glad you did.
The vertical pull starter cord is a preference rather than a clear benefit. It works fine, but I found one drawback. When the vertical pull apparatus is installed through the opening in the engine cover, the rubber sound insulation gasket which surrounded the stock "horizontal" pull cord is removed. As a result, you get a little less sound insulation and a little more noise with the vertical starter. I would try the stock "horizontal" pull cord on your boat. If you have no problem with the stock pull cord, stick with it. If you have a problem with the stock "horizontal" pull cord, such as part of the bulkhead obstructing a "clean" pull, or are otherwise uncomfortable with the stock pull cord, you can always add the vertical pull.
MRH
