Results 1 to 15 of 250
Thread: Outboard Discussions
    Jul 2007
    South Portland, Maine
    My long shaft Tohatsu 6 worked pretty well but the zinc is so little that it was useless. After about two months on the mooring it was gone. This year I put bigger zinc by drilling through the captivation plate. At the end of the season I was bringing the boat over to the marina in a 30 knot wind when the motor failed (it kept running but raced as something went wrong with the prop or lower unit. It looks like the lower unit corroded through in a pinpoint hole. The bigger zinc method worked with my old outboard for 10 years so I'm not sure what happened. Looks like a $500 bill to buy a lower unit . . . not what I was expecting.
    Quote Originally Posted by Orca View Post
    Wow!
    I am sorry to hear this. Both for you, and for me! I sure hope you don't need a new lower unit, maybe it is just the pin?
    I pull the motor out of the well now, but did not with the Yamaha (I sailed more days then i did not when I was in NC.)
    The zinc issue is not for the daysailor, but for the cruiser (as I see it). When cruising, you are simply not likely to pull the motor each time you anchor.
    Even if it were not difficult, it would not be advisable, sometimes things happen that you need the motor for on a 'dark and stormy night'.
    My old Yamaha 6hp 2 stroke had a big zinc, and would be happy for 6 months in the water...
  1. Outboard Well
