Frank, A-50's "cabinetry above both settees" is custom by some previous owner. Ditto the companion way door, the cover on the chain locker and the deck scuppers. Early boat's scuppers were 1/2 inch leading to above the water line through hull fittings. Not real efficient. Later boats had one inch scuppers, but in all caes, as the hull laminate saturated, hardware was added and gear got stowed, the low point usually moved aft . . . leaving the scuppers forward of the point where water tends to collect when the boat is docked. Filling the water tank and moving gear forward (& storing the ob on the cabin sole) will help.
