After 18 months, these cheap $10 3" computer fans from Radio Shack still work. I leave them on all the time (except in this photo). This one pushes out into the cockpit. One under the front cowl vent draws air in. They keep the air moving through so I don't show up to a stuffy, smelly boat. Heck of a lot cheaper than those $100+ jobs that WM sells. Can seal off the cockpit vent---- in foul weather. Lots of water could come in here in a big blow if you're pooped. This hole is where the old mechanical knot meter was located.
And front to back. Hey Tony, I know you love pictures, but don't look at those curtains too long or you'll go blind. Say Ebb, you been researching what you're going to paste on your portlights? Haven't heard anything on this subject. Maybe we need to start a "bilious, hilarious, awful" curtain thread!
Kent, keep the photos coming!
What kind of boat is that?
Does it have an enclosed head?
Sauna?
ebb will no doubt go on and on and on
and on
about his deadlight situation - which is
different, mind you, than mounting wood.
Aough oh... (here he goes)
I don't think the original installation can
be made water resistent without filling
the space between liner and sides, like
what is shown in the Gallery photos.
Will seriously consider using BoatLife's
hybrid sillythane for the outside frame.
[want to get in the pit with ebb on this,
let's start or find an old subject thread...]
I am thinking about getting the outside
frame on first like a week ahead and then
putting the lights together from the inside.
Will research the butyl option as the lexan
has to float between inner and outer
frames to get a true seal.
To do that, the lex has to be prebent.
Not a biggy. Just has to be done. Good
winter project!!!
hi Kent I was just admiring the fine job you have done on 376. The picture of it on the hard just after the paint job reminds me of 2 things. 1 - Albergs fine underbodies make them look as good out of the water as in it ! 2 - it made me think of an article I read in cruising world by Bernedette Bernon on that "majic moment" when after all your work you can finally "peel back the tape" step back..and look at the finished product you"ve created. How as you peel it back ...the boat comes to life. I am sure you were very proud when you "peeled the tape" on 376 !! Job WELL DONE ! #50
I went with about 10 other sailing vessels to Smith Point this past weekend. Only 15 miles by water from Houston's Clear lake, but a hundred miles by land. It was a different world. Nothin but oystermen, shrimpers, and birds. One of the boats caught this pic of us just underway
I just noticed in Post #12 there seems to be a "cove" on the right where your counter top follows up under the port cockpit seat. This confused me, because my back splash is straigh accross, from under the c'way from what I imagine is the well in the cockpit floor, to the port hull side.
Edit: Also your boom seems high, is it on a track or on a fixed mount? I was thinking about ditching the down-haul track. (does it make sense to have a down haul and a winch on the hallard?)
My family has owned this boat forever, but I think at one point in time my dad or one of his buddies might have decided they wanted to have more storage around the galley area, and so there is this cut that then extends the counter top to a shelf which extends into the port cockpit hatch area. FYI, to better air condition the boat in this Texas heat, I made a cover to fill in the hole. I still use the shelf, but access it through the port cockpit hatch.
And yes, my boom is on a track on the mast....... this boat came that way.
