Here's a question demonstrative of blatant ignorance. What is a reef hook? What is it's primary task? Yes, the name suggests when it's used, and, it's basic shape indicates that it holds something down. But what does it hook to or to it? Is a reefing line that runs through the reef point tack tied off to it or does a ring hook onto it? None of my other boats have one and I've (obviously) never used one.
Because we're adding a rigid boom vang I thought I'd have a fixed gooseneck made this fall. I somehow neglected to notice the reef hook(s) on some of the goosenecks that I looked at for desing ideas. Yet some of the designs didn't have one at all. So I did not include one in my plans just to simplify things(K.I.S.S.)even though the original assembly had one. Now I'm seeing reef hooks everywhere even in my sleep!
It seems this question should have been asked BEFORE I went to the shop plans in hand.![]()
Maybe all is not lost. The reef hook that came off the boom has a hole in it where it was attached to the casting with a screw. That screw hole is exactly large enough to allow the pin of the d-shackle (that acts as the mainsail tack pin)to pass through. So I could attach the original reef hook to that pin and have a mobile hook much like the original design just different. Does anyone see a definite problem with this? Is the welded reef hook essential or prefered for the proper function over the original moving design? Have I wasted another $100? Tony G
