Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Thread: Commander sink option? does anyone have this?
    Sep 2003
    Hello Everyone!
    We have commander #155 in san francisco. Our boat does not have the sink option in it. But it seems like a great thing to have.
    Does anyone have this option that can tell me a bit about how it works? (water tanks? hoses? constrution of the sink area?)
    I would like to try to replicate this very closely and make it for our boat.
    If anyone is near san francisco, I would be glad to take you to lunch if I could peek at your original sink and take a few meausements.
    Has anyone had any troubles with this upgrade? any disadvatages or extra risk of leaking?
    If anyone could post a few photos of your sink it would help me out a ton!
    Jul 2002
    Live in: Ocqueoc, Mi Home Port: Drummond Island, MI
    Post Commander Sink
    We have the original sink in our commander. We did install a flexible tank under the starboard berth for carrying fresh water. What measurements do you need? I can also take pictures. We will be going to the boat this weekend and I can post them on Monday.
    Fair Winds!
    Liz Fagel
    s/v Fagel Attraction II
    Pearson Commander #75
    Sep 2003
    Thanks for the help! As for measurements: overall hight, lenght and width. Perhaps the size and depth of the sink. And any other demisions you think would be helpful?
    For example I have never seen the sink, so I have no idea how it works? are there drawers under the sink? if so it would be great to have measurements of that as well.
    for photographs, the more the better, because I will be attemping to replicate it.
    top veiw of the sink and under the sink would be great also!!
    Do you like having it? do you use it alot? Maybe I dont know what i'm missing.. haha.
    Where does the water come from and how does it exit?? That would be great to see also!!
    Thanks so much!!! Anytime your in the san franicsco area, lets go for a sail!
    Here's a few photos to get you started.
    Its a simple affair really. Three pieces of plywood (a top, front and side) covered with mica. Cut outs for the sink, a drawer and a door.
    Don't use it that much. The drawer is handy.
    With the unit removed you can see a hole is cut in the berth.
    Starting at the bottom is a hole cut in the hull with a short fiberglass tube formed around the hole. A piece of hose over the tube, then the float valve (the loose piece pictured), then another piece of hose leading to the sink drain tail piece.
    This arrangement could all be improved.
    The cruddy green garden hose led from the water tank to the sink drain pump.
    Jul 2002
    Post Commander Sink
    Our sink is exactly like the one that Commander Pete has posted pictures of.
    We normally do not use the sink when just daysailing or staying overnight at the dock. But when we are cruising and living on the hook it gets it use. Brushing teeth, washing hands, making coffee, water for cooking, rinsing food. We don't wash dishes in there as it is too small, I carry dishpans and do those in the cockpit, using dawn dish detergent, and we toss the "brown" water overboard.
    If you need to drill a "new" hole for the draining of the sink, I would put an actual thru-hull on for safety. That way you can close it when not at the boat, sailing, or just because you are not using the sink. I do have a picture of the thru-hull we installed for an intake on the head in the forward v-berth in the gallery.
    I thought I had posted pictures in the gallery last year, but that was of the conversion we did installing a head and making the old water tank into a holding tank. I will take a picture of our "new" flexible holding tank and will do any measurements that I can get for you.
    Have a great weekend!
    Liz Fagel
    Sep 2003
    thanks for the great picture commander pete.
    I may have more questions as we start making the sink. It looks like you epoxed the bunk over the wood? is that true? to make it a smoother finish?
    Liz, I look forward to your picts and measurements! It sounds like a usefull addition to the boat!
    Can the drain hole drilled in the boat be above the waterline? to minimize risk of sinking?
    So is the upper drawer a "drawer'? and the lower drawer a cabinet that opens to under the sink?
    Thanks guys!!
    The upper drawer is a pull out drawer.
    The lower door is a cabinet door.
    I don't think you could put the discharge hole above the waterline. The bottom of the sink is only about 4-6 inches above
    the resting waterline. When the boat heeled over you would probably get some water gurgling back up the sink.
    Here's a picture of the sink unit while I was taking it apart.
    I have no idea why I was fairing out the wood under the sink. I must have had some leftover goop.
    Jul 2002
    Post Pictures & Measurements of sink
    Here is a pic of the front of our sink. We used this area to install some of our electronics. The width is 15" and the height is 20".
    More pics and measurements to follow.
    Liz Fagel
    Jul 2002
    Under the sink
    This is the picture of the cabinet door open and what is under our sink.
    I didn't get the door measurements.
    Liz Fagel
    Jul 2002
    Sink Drawer
    The drawer measure 7.5"w x 12"l x 4.5"d
    Here is a pic of the drawer.
    Liz Fagel
    Jul 2002
    "Top" of cabinet and sink
    No picture of this as it is the same as Commander Pete's.
    The top of the cabintet measures 15"w x 26 5/8" d
    The sink measures 11 3/4"w x 9 1/4" d
    I have attached the pic of the deck water filler that we installed for filling the flexible water tank.
    Liz Fagel
    Jul 2002
    Thumbs up Flexible Water Tank
    And this is a picture of the flexible water tank that we installed underneath the starboard qtr. berth.
    Liz Fagel
    Sep 2003
    Thank you so much for sending the pictures of your boats' sinks. They look great, they are a big help and very inspirational.
    Commander Pete, I was wondering if you took your sink out of the boat in order to restore it. If you did, can you tell me how you re-attached it?
    May 2002
    Manchester, MA
    Water tank.
    SailorLiz,
    Did you have a tank uner the v=berth? My tank was shot and I have removed it. I am debating with myself about whether to replace it with a bladder or a poly tank and were to put it.
    My sink is just like the others. And the undersink area is a catchall for sure.
    John G.
    Valhalla
    Commander No 287
  1. Commander #5
    By commanderpete in forum Gallery
    Last Post: 10-31-2006, 09:01 PM
  2. Commander headed to Hawaii !?
    By Rico in forum General/Off-Topic
    Last Post: 07-04-2006, 12:39 AM
  3. F.S: Commander, Martha's Vineyard
    By commanderpete in forum General/Off-Topic
    Last Post: 10-07-2005, 06:05 PM
  4. Carl Alberg's Commander
    Last Post: 07-25-2003, 02:18 PM
