The break is probably in the upper half of the rudder shaft, so you will need to purchase only half of the total shaft (and have it bent). Several sources of "marine bronze" 1" rod have been noted in earlier posts.
As for "stock" parts, little is currently available. Patterns for deck hardware and fittings are out there and we may have a source of those items in the next year. (See Ronstan, RI and hardware posts.) Stemheads, rudder shoes and the like are all custom. Bristol Bronze has a stemhead pattern (courtesy of Ebb) and he and others have had, or are having rudder shoes cast.
Please let us know the hull number of the boat that has your interest. And be sure to register it, if you make the purchase.
Bill
