Ok, I have re-evaluated my position on onboard refrigeration.
Having no icebox, and no desire to build one, I have opted for one of the small self contained units, specifically the Engle. The other one I looked at was the WAECO ADLER BARBOUR, now sold by west Marine.
Here is the add;
WAECO ADLER BARBOUR CF-025DC 7895808 Only $569.99 USD
Fully hermetic Danfoss BD35F compressor with integrated control electronics, low-voltage protection adjustable for consumer or starter battery by means of a slide switch, electronic fuse/automatic reverse pole protection, dynamically ventilated wire condenser, aluminum rollbond evaporator.
• 24 quarts
• 12/24 volts DC
• 35 watts
• +50°F to 0°F, adjustable via electronic thermostat with LED indicator
• 26.5 lbs.
• CFC-free polyurethane foam
• DC connection cable, detachable wire basket
• Detachable lid (lid mount at the front), interior light
• Vertical space for standing 2-liter returnable bottles
CF special electronics
No mention of the current draw beyond the 35w number. Given that this unit uses a conventional compressor, I expect they went with the 35w rating at 12vdc, rather then publish the current draw... can't be sure.
The Engle uses little current, and fits into my energy budget. I like the fact that there is only one moving part in the compressor.
[img width=419 height=650]http://www.thermaldynamicssales.com/images/Engel%2520Compressor%2520C-Section.jpg[/img]
I looked at a few models of the Engle,
The Engle 15, 14 Quart
• Outside dimensions: 14.5"H x 11"W x 17"L
• Inside dimensions: 13.75"H x 7.5"W x 7.5"L
This would have fit best onboard, and the storage space would probably have been adequate for my needs. The issue with it (for me) is that is has a slightly higher advertised current use then the larger models (probably due to less insulation).
Then is was the 16q, or the 22q. They both have the same advertised current use… .7 to 2.5a
• Model: MT17FU1
• Fits 24 cans (12 Fl.oz) Dimensions: 14.2"h x 21.1"w x 12"d
Then it was the 22q model, (model 27)
Power Consumption: 0.6 - 2.3 Amps
Fits 30 cans (12 Fl.oz • Dimensions: 21"h x 12"w x 18.2"d
From there you go to the 34 and 43 quart models.
I like them for their capacity, but they would not fit on my boat without some modification.
Model: MT35FU1
Volume: 34 qt. / equivalent to 54 12oz. cans
• Outside dimensions: 16"H x 14 1/3"W x 25 1/2"L
• Inside dimensions: 15.4"H x 10.8"W x 12.4"L
0.7 Amps in refrigeration mode; 2.5 Amps in freezer mode
Weight: 46.3 pounds
Model: MT45FU1
Volume: 43 qt. / equivalent to 60 12oz. Cans
• Outside dimensions: 20"h x 14 1/3"w x 25 1/2"l
• Inside Dimensions: L 15.4" x W 10.8" x H 16.4"
Weight: 52.9 pounds
I took the measurements out to my boat, and figured out that the model 27 was the right one for me.
I like the model 43, but the 25” length gets me. I would have to stow it lengthwise in my v-berth, or rebuild my interior to accommodate it. This would take up too much space, and the lid would not open more then ½ way.
The 18.5" Model 27 should sit at the aft end of my V-berth (on the port side) and the way the lid opens from the end should make it a perfect fit.
Looking around I found Compact appliance (the link Connie suggested) beat all others, and was actually cheaper when I checked out then their own advertised price! (It lists for $569, and sold for $534!)
I will post my impressions when it arrives.
