Page 1 of 2 1 2 LastLast
Results 1 to 15 of 22
Thread: Unsat
    Unsat
    In the early 80's when I had to march in a straight line if someone said 'unsat' it meant unsatisfactory. Well lo and behold it's the early notties and it still does. Here are just some of the spots on 113 that I found unsaturated glass. Some of it is just superficial some has been a little deeper. The superficial stuff tends to be located on/or in the area of the hull deck seam so I don't know how 'superficial' it really is.
    Aft starboard corner of the lazerette...
    I think this is a closer look. We'll see what happens after I push the button
    Nope! Sorry, that was inside the starboard cockpit locker looking aft. Unsat just the same.
    Dang! Good thing this is just a mouse and not a hand gun. I'd be pokin' holes in everything around here! Still-unsat in the stem. Here's a broader view...
    Gaps and holes everywhere. Maybe I should rent a chopper gun and throw in a hundred pounds along that seam...
    WHOLLY JEHOSEPHAT!
    Well. I'm not completely sure what we're looking at here. Last foto is of the forward bulkhead at the stem?
    Of course you'll be checking with your epoxy friend....but dig, cut, grind out the unsat IF IT IS NOT THE HULL LAMINATION and fill it properly and retab the bulkhead to the hull.
    If the unsat is also the hull, WHICH I CAN'T BELIEVE, we need further discussion here!!! - especially with input from Mike.
    In 338 there is a lot of roving used for the hull in the rear where finish was not deened important - sand away the paint where you intend to repair befor you epoxy. That looks like paint on the roving. Sorry if I sound patronizing. Looking at Geoff's. I wonder how close is close enough?
    That last photo is lying on your back looking up at the deck at the stem. You're right, that area still needs some prep work. Enlarging the chain locker opening was one of the last things I did on the boat and the was entirely to facilitate working in that area. About that paint, I'm still looking the right tool or technique there. I fashioned a clamp for a 6" wire wheel and that has worked great in the toe-rail cavity. Hours with the 4 1/2" angle grinder and 36grit. But up front in the chain locker when I use the grinder it starts exsposing the raw roving fibers and I'm uncomfortable with that. There may be enough layers there but I'll keep looking until I hear otherwise. The wire wheel worked ok, maybe I'll just have to put in more time.
    There are two minor bubbles on 113 where edges of roving wrinkled and left a pocket. Nothing outrageous, easily fixed.
    Of course that same angle grinder does not have a vacume pickup. We tried everything including working with the grinder in one hand, vac hose in the other. Nope. Saw somewhere an after market soft plastic hood attachment for the big angle grinders.
    The only mask worth a damn is the nofog airwash one, but it's too cumbersome. Still have the bilge to depaint, after the sole comes up. Might use Strip Away there. Have a sensitive nose - find the smell of freshly ground old polyester very offensive. Danger sign.
    Keeping a work/time log sounds very organized. Does that include time spent figuring out how to squeeze in a bunk long enuf to sleep in? I have to have standing room also - so have removed the step-up at the companion way and intend to figure out a way to have a pull out ladder from under the bridge. OR more likely build in steps off the built-in furniture, somehow appropriating the headroom there where the ladder can't be!
    If you've permanently removed the factory icebox, serious 1/4 berth length can be found under the stbd side lazarette. Looking into that. I think the Alberg CD25D had them - or one.
    The aft chain plates knees seem extraordinaryly important to me. Are you replacing them?
    Or are you planning to put REAL chainplates outboard on the hull???
    Unsaturated roving/glass sounds serious. This is a problem with modern fraudulent boat builders, not sloppy honorable ones like Pearson.
    However, as you know, the plastic 'wets out' the fabric but doesn't saturate it. Plays on words perhaps. Could say the plastic encapsulates the glass fibers. Roving came in serious bundles or strands barely interwoven together - some of them maybe didn't get soaked good. The factory guys finishing up the boat must have been working really fast, or the poly went off befor they could pour on more and work it in. ???
    But I think you're merely scouring the surface of the roving bundles with the grinder. After the paint comes off, you probably can repaint it with epoxy, or even add a layer of X-mat. What do you think? No loss of strength or integrity.
    The 25D has a stbd quarter berth , the galley is to port with a locker in the port cockpit seat. The stbd seat has just a very shallow locker ,good for line and winch handles.
    Ebb
    I'm going to replace the aft chainplate knees with 3/4" ply. Right now we're at a point where I feel I must put them in using the remainder of the mainbulkhead as a landmark for alignment. Once they're in...well lookout! most of what's in there now is going to come out. But not until I get busy on that deck seam and toe rail/rub rail after all I'll need something to lie on. Still toying with the idea of inboard desiel.
    Interested in your deck/hull seam upgrade......
    After being alerted by a well placed individual here on the West Coast and primed with hard information, I sought out the 10hp BETA diesel at the recent boat show. Very nice and tidy - all the important stuff is on the front, so you can pull kp without getting a hernia. It evidently takes no more space up than the factory Atomic 4, weighs about 180 lbs. I hear it's a marinized Kubota. Don't know nuttin bout no Kubota, but when guys mention it they look in your eyes and expect you to say, 'well, hey, that's a purdy dependable engin, ain't it?'
    One convincing point about the Yamaha 338 got was that parts (and mechanics?) are supposedly available world wide. Same is true for the K., I heard.
    Rick, with the Triton next to me at the yard, has a Volvo - nothing but trouble and parts for it are explative expensive.
    Apr 2003
    Bellingham, Wa.
    inboard vs. outboard
    at one point i had a slip neighbor who also had a commander. this was when 280 still had the a-bomb. both boats were in very similar condition, with similar sails in terms of cut and condition. guess which one came about more smartly, pointed better, and accelerated faster...not mine.
    it's my understanding that MORC rule at the time the boats were built required an inboard auxiliary, which is why the thing was an option. i can tell you that the performance of the boat without the a-bomb was night and day better. before i took it out and replaced it with oars and chute, i was going to take it out and cut in a motor well like my neighbor's had.
    hey...if you just gotta convert, though, or if you really like a lot of extra gas for the outboard, i have something for you!
    dave
    Imagine how I'm sweating the 110 pound Yam aha - Plus the built-in gas tanks (maybe 8 gals each) - Plus the battieies under the cockpit - Plus all the cruising gear on deck in the rear - Plus the weight of all the epoxy work - Plus the bloody captain!! 338 is going to squat to its chocks. A BETA in the bowels may have something to say for it. Being down where the weight ought to be.
    Good ole Charlie MORC - was more concerned with offshore safety than banging around the bouys. Well may be why Carl had an inboard designed for every Ariel and Commander. They all are built to accept an inboard, viz a vie the propeller aperture in the keel and the two-part rudder shaft with the upper bend. Not so??
    "They all are built to accept an inboard, viz a vie the propeller aperture in the keel and the two-part rudder shaft with the upper bend. Not so??"
    Must be so. That's what all the Alberg drawings show . . . and in those days, the Atomic -4 was about the only option. The Beta is probably close to half the weight? That would improve performance . . .
