Results 1 to 4 of 4
Thread: New Cleats
    Mar 2012
    Aptos, CA
    New Cleats
    Here is one of two new chrome plated bronze cleats which I bought from Historical Arts and Casting to replace the Ronstan originals which I stepped on. At $200 each I don't expect them to break. Actually, it's a W/C design. Will repeat the saga of the new cleats soon.
    It's so beautiful!
    Mar 2012
    Aptos, CA
    Cleats
    They certainly are. Haven't been able to install them yet due to construction at the house. I did go about acquiring them backwards, however. Not thinking about the forum, I measured the hole pattern and found what I thought was the perfect match from Rig Rite Co. back East. I bought what turned out to be an unused Wilcox Crittendon cleat for $180. Unfortunately, the hole pattern was perfect only if I turned the cleat 90 degrees. Dang! I installed it for my traveler by using only 2 screws which then fit with the cleat facing fore and aft. Then I broke another jib cleat, and found an ancient W/C plated bronze cleat for $30 off of Ebay. I installed it to mind the traveler also. Finally, I remembered the forum, found Historical Arts, sent them the broken cleat for sample, and I now have 2 new plated bronze jib cleats. Will check back in when they are installed.
    Mar 2012
    Aptos, CA
    New Cleats
    Job complete, everything fit. Time for a 2 beer daysail.
