I like the way it does not rest against the transom and scratch it up. It is one of the ladders I looked at but it was only rated at 200 Lbs. and I weigh 212. It is good to hear that it seems plenty strong even with it's rating.
My biggest problem with mounting a ladder on the transom is I did not want to cover any of it up and your solution appers to keep the transom clear. And the back stay gives you something to hold onto when climbing aboard. Thanks for posting the pictures it certainly gives me something to think about.
The way Ebb has done his outboard on his boat this solution would not work for him. But Destiny will have an inboard electric drive and a prop in the aperature at the end of the keel. Quite a bit further away than an outboard prop would be. Hmmmm....
