System three's website must be down cannot get it to come up. Even tried the link from a Google search.
I have a moisture meter for wood. The way the meter works is you input the specific gravity for a species of wood and then when you lay the meter on the wood it will tell you the moisture content of the wood.
So today after doing some fillets down below I decided to start tackling the deck issue. I looked up the specific gravity level of balsa and it was .17. My meter only goes down to .30 so I set it at the lowest setting and thought I would give it a try anyway on the deck. Well the meter read 20% moisture everywhere I placed it on Destiny's starboard deck near the cockpit so I though it would not work correctly on balsa.
Then I started drilling holes in the deck and as soon as I would reach the bottom of the top skin with the drill bit it would fall through and bounce of the bottom skin. Oh NO!!!! Well I started cutting it open and here is what I found.
Let the games begin.
