Thank you for the complement but I for one do not believe working with veneer is out of your reach. You have the self discipline to do the job well. And small pieces like these are really easy to do. Large ones really require a vacuum press to get them well bonded without bubbles. These I was just able to put clamps around the perimeter to hold everything flat.
Like your use of a roller to spread epoxy resin evenly I use a rubber roller to spread glue (Titebond III) to the surface of the plywood. Then I lay the veneer on top and a piece of waxed paper which is followed by a piece of scrap plywood. Then just clamp it up and let it dry. Really it is very easy.
As far as the cork spacers you are absolutely correct that I added them. They serve two purposes. One as spacers to make the tank fit snuggly and two as a cushion to eliminate wear from the tank rubbing against the hard plastic hull. I used 1/4" thick layers of cork and contact cemented as many together as were needed (usually 2 but one location needed three) at each location to get the tank to sit solidly without movement. I also held them in place with contact cement between the hull and the cork.
For the deck fill for my water tank I have attached another picture that tells the rest of the story. There is a brass or bronze cover (not sure which) that is chrome plated and it is the only thing exposed on deck. The marelon is all below deck with the exception of the very edge of the top. it is exposed around the perimeter of the chrome cap.
