Results 1 to 15 of 422
Thread: Commander 147
    THAT'S BEAU*TIFUL WORK.
    you know me. the fly in the ointment...
    The quick fix for sagging beams and flattened coach roofs has been thru-bolting a piece of
    metal plate across the span to the ole beam. It's in the Manual.
    But it occurs to me that a beam of your excellent proportions
    could have a 1/4" slice taken out of the center (not through the cabon layer!) - the long way - and replaced with a carbon insert like the one on top. Or of course stainless.
    But carbon is the theme here.
    Given the stiffness of carbon, and the epoxied-in 'plate' supported against deflection by the wood on either side, you'd have a compression beam that would NOT require a post..... a non-compressable beam.
    Beam ends would need minimal vertical support of course.) Just being helpful
    (buzzing off then.....)
    Thanks for the complement Ebb.
    Steve Koopman who designed this for me says it will support 7000 lbs. with a 39" clear span between the bulkheads the way it is. There will not need to be a compression post in my commander when I'm done. Take a look at post 119 below and you can see what it will be like when I'm done.
    Oh and please keep bing the fly in the ointment. :-)
