I'll get you a shot or two soon.
The blade can be put on at many angles to the head - straight out, 90* to one side or the other, basically any approximate increment of say 30 degrees around a whole circle. So at say 90*, you can stuff it into about a 3-4" wide space and cut away, to the left or the right...
Also, it is good at flush cuts, so tabbing against the hull comes away very cleanly, leaving little to have to sand. That sort of thing...
