Results 1 to 15 of 422
Thread: Commander 147
Threaded View
  1. #9
    Ebb that sounds like it would make a nice looking tiller
    Not sure it would work with my design unless I eliminated the knob on the bottom side of the tiller. I need all of the laminations to get the height for the knob. And that is also why almost my entire taper is on the bottom. This leaves the top piece almost intact and continuous.
    As I was typing that it occurred to me I could just glue a couple of pieces to the end of the bottom afterwards to make my knob.
    I do have one bottom strip that dies out completely and a second one that comes close which leaves the very obvious glue line from the resorcinol on the bottom which you can see in the picture below.
    I also agree with the thinner strips thought. I honestly think I could have made mine thinner than I did which was 1/4". But when I did my test clamp up everything seemed to work OK so I went with it. But thinner strips would have created less stress just more glue lines.
