Ebb and anyone else with thoughts on the matter...
I have to say the added bulkhead makes a hugh differance in the rigidness of the aft end of the keel. But another added bulkhead above the aft end of the main ballast and biax tying that one to the other one I already installed would make the area incredibly strong. I will have to take a serious look at that.
Another issue I have and I don't know if the Boat came out of the mold that way or if the Vermont freeze thaw cycles caused it with the wet foam in the keel. But I have some humps in the port side of the keel in the area where I took all the foam out. I've sanded off the filler the boat yard had put on the keel in that area and it is not a repair or anything like that. It is the original fiberglass that makes the humps. Since this is also the area where the boat yard had sanded through the gelcoat I figured I would finish sanding of the gelcoat in that area so the epoxy would adhear better and fair the hull with some epoxy and microballons then after fairing it out apply the layer of 6oz cloth over the epoxy filler and and finally fair that out before I redid the barrier coat and bottom paint.
Opinions on my plans are welcome.
