Hey Kendall, you're scaring me!
No over-bore down there!
It's just fiberglass, what there is of it, NO CORE.
My fix:
Scrape the cavity with carbide scrapers (Bacho) Remove any loose stuff.
Make paper patterns (Really!) of the port side and the starboard side (obviously they are flipflops)
Allow ONLY one 90 degree turn into the ends and on the bottom. NO U TURNS, they get out of control.
Cut XMATT so that each panel you put in laps only over the other side's panel in the end and the bottom of the keel.
Xmatt is stiff enough initially so that after you have cut it to the paper pattern size you can FIT it into the cavity AND take it out again. You will want to remove darts of material where it wants to bunch. I would put in at least 2 layers of 24oz. What you are doing is also a dry run. Epoxy has a short open time after mix. In the cup it is way shorter than when spread thin. Epoxy when it's cool.
Lay out some plastic film, lay the cut-to-fit Xmatt on it and wet it out with 2part epoxy. Drape it into place in the keel which has also been wet out (IMPORTANT, make sure you are putting wet material on a wet surface. Only way you can get a mate, with no holidays.) Unlike woven fiberglass, you CAN reposition Xmatt, just not too many times befor it starts falling apart.
Use a throw-away brush to poke the Xmatt into the corners. I go so far as to sharpie pen hash marks where the turns are to be on the fabric. It makes positioning easier when it is wet. If you feel you can put the second layer on top of the first wet layer, go for it. Otherwise let it stiffen up some, or come back the next day. Next day will no doubt require some prep. I like to alternate one side's lap over the other for the strength it makes. Use the brush to poke the fabric into the epoxy. If you have created a bridge with the fabric over a depression, slice the wet fabric with a utility knife and pat it down. Patch it later if needed, or paste on a piece of scrap.
If the surface is too weird and you know you won't be able to get a solid no holiday layer, you can mix up some epoxy and fumed silica gel to smear over the problem 'cavity' just before the fabric Quickly. Just pat it flat with your latex gloved hand.
After your reinforcing layer(s) are in, then you want to add a bunch of mishmash (2part laminating epoxy - f. silica - 1/4"/1/2" chopped strand fiberglass.) Mix it stiff so you can sculpt it over the area where the gudgeon fastenings go - so the the fastenings are not exposed in the keel cavity. Tab in a piece of Xmatt or fabric over the glob so that it ends up relatively smooth.
Xmatt leaves a rough surface. After it is set you may want to smooth it with the gel mix. A good smoother is the pliable green applicator that seems to be everywhere.....you can spread the mix on really smooth so that there is little work to do after it is set.
After this work is done then you can add a 'garboard' drain plug. Make sure it is bronze.
You now have a nice sump to collect water and to have a bilge pump or two.
I'm in the full access camp for boat maintenance. Foam makes access impossible and creates more problems than it cures. Fit a lid over the area so socks won't get in.
All imco, hope some of this is helpful, sorry if it seems patronizing.
It's impossible to know what has been in and out of the bilge in 45 years. To know what oils and waxes and stuff have been there - ARE STILL THERE.
NO, can't use solvents - out of the question. Scrape, abrade, grind - these are impossible but not lethal. The Fein tool will allow abrading and scraping near to the bottom of the keel. Any solvent will screw up the epoxy or any coating going in there next.
Must use 100% solids NO SOLVENT epoxy - unless you want to die. Do not use West System epoxys here. Some of their epoxies blush and some use formaldehyde in the hardener side (205). Set up ventilation under the cockpit when working there.
