Your thoughts are very similar to mine...
As a matter of fact two days ago I was looking through Ebb's gallery to look again at the keel area work he did. I want to add a brace or bulkhead or what ever the correct term for it would be just in front of the rudder shoe since this is a lifting point and it needs to be strong. I thought I would pack some thickened epoxy with glass fibers down in the bottom of the keel to bury the area where the rudder shoe attaches and make sure it can never leak there. Then add the brace. I also think I will slope the glass that encloses the keel down into this area so everything drains down to this low point. Then I will run the suction hose for the bildge pump down there.
I like your idea of the light to locate possible leaks. I will have to try that. I can see light through the keel in the areas where they blasted through the gelcoat already.
You're right it is not pleasant work. I work a couple hours each night and come out soaking wet with sweat. The temperature here in Florida has been running over 80 degrees at 8:00PM and over 90 degrees at 5:00PM. Hard work for a guy that spends his days in an office on the phone but well worth it in the end.
