next is a small hole in the hull right above the cockpit drain, It does not go all the way through the hull, just into the drain channel, but all the same, I want to take care of it.
Not sure what you mean there, do some Ariels have the tubes glassed along the side of the hull?
Mine are just glass tubes on the bottom connected with hoses to the cockpit.
