great coaming repair
Like the wrinkle of your driving the allthread in with the driver.
Should be locked in there til kingdom come.
I believe it may be better than what 338 got which were two 6" long 1/4" bronze rods in each of the corners. Drift pins!
I'll wager there isn't a single Commander or Ariel that doesn't have this splitting problem coming out of the knotches.
The rod may be all that is needed - yet the coamings get a lot of bending moments on them - not from sitting against them so much, but sitting on them, and sometimes standing on them.
The aft end might also have a small corner block added on the deck at the end - with it screwed into the coaming and the deck, Something to make absolutely sure the top can't be moved on these 'open ends'.
That is one of, if not the best fix I've seen in a long time. Besides, anyone who so aptly uses the word 'smothered' gets my vote.
