Page 19 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 LastLast
Results 271 to 285 of 619
  1. #271
    After the longest five days of my life waiting for more epoxy to show up we finally got the last two layers of fabric down on the seahood!
    So all totaled we have two layers of 1/8" baltic birch, one 1/4" layer of closed cell foam, two layers of 8 oz.fabric, three layers of stitched matt, two layers of 17oz. roving and a cover of 6 oz. fabric. That may seem like a bit much but it may get stepped on accidentally and I wanted that styro nose solid.
    Now, if I can just figure out how I want to mount the traveler we can get started on the cockpit coamings.
  2. #272
    Looks top notch Tony... care to do it again on Faith?
    I sure do like the traveler aft... especially for a cruising boat. Works well for going below, and the loose footed main seems to want end of boom sheeting IMHO.... but then there is a great big old thread on that IIRC...
  3. #273
    Craig
    I'd love to help with anything on Faith. I must have been dropped alot as a baby because I don't mind the itchy, I don't mind the cramped spaces checking something twenty times to see if it fits yet doesn't really bother me either. But, I really get annoyed when I epoxy my hair to the back of my head
    End of boom sheeting really does seem like the logical answere precisly for the reasons you mention. Way, way back when Bill first shared his mainsheet set-up on 76 I ran out and bought one based on his unfettered praise. (going to copy his outhaul assembly too!)
    My big hurdle now is wether to mount the traveler on the coaming, outside/behind the coaming or inside/forward of the coaming. On the coaming I would have to eliminate or reduce the amount of arc on top of the coaming that would mirror the lovely curve of our deck. Outside would be ok but then we have to add fairleads or tubes through the aft wrap of the coaming and move the traveler car control line camcleats to the inside of the coaming. Inside would be easiest for traveler operation and mainsheet set-up, however, I keep seeing some really tough angles and crevices to lay glass into.
    For a while now each time I go up the ladder into the cockpit I look at that general area and no revelation yet. Anyone have an idea? A picture or two?
  4. #274
    Found another candidate,(No, not one of those kind), and a Carl Alberg design to boot. What if the coaming wrapped around the lazarette hatch? Then the traveler could stay in the same spot, I could have my arc in the aft part of the coaming and maybe add one of those bimini tops that drop aftward! Ooo! 'just gave myself goosebumps!
    I like the turning blocks. They would lend a kind lead to the winch if we're flying the MPG/Asym.
  5. #275
    Flying biminis on sailing condos seem to be the rage these days.
    Sept/Oct '08 Good Old Bateau has a guy talking about his 39 footer with a split-level transom.
    "Two practical uses for two stays aft"
    Split or double stays can mount the radar on a cross tube.
    And also if you have a detatch tube frame bimini you can anchor it between the two wires aft.
    An interesting variation having a 'mid-boom' gallows is explained. It also anchors the forward end of the bimini. And the author mentions we builder types start from unassailable points of view planning and building and then have to make important changes after gaining experience sailing it.
    It's hard to figure where the mainsheet leads are.
    His furled mainsail in the lead photo is one of those that incorporates a fully deployed sunbrella cover along the boom when the sail is up.
    The dodger like the bimini is an all tube, rag and isinglass affair. It all looks like it can be taken down and stored below in case of a hurricane.
  6. #276
    Hey Tony
    Excellent work.
    Sounds like you're planning a wraparound coaming. Would look nice, and provide more comfortable seating on top.
    I cant see a good reason to have mid-boom sheeting if you have a boat where the boom reaches the end of the cockpit.
    I would try to make the traveler as wide as possible. On many boats you only have about a foot of adjustment on either side--limiting the effectiveness of the traveler.
    Here's what a few builders have done:
    1st pic is a Schock Harbor 25
    Next 2 pics are the Harbor 20
    Then you have an Alerion Express 28 and 33
    I hear what you're saying C-Pete. Used to "sail" on a C & C Mega 30 that had one of those 24" travelers right through the cockpit and of course at shin hieght. It was a bit of a challenge to move it to windward, or move it period, specially if the skipper thought he was Dennis Connor. Thinking back I'm amazed nobody lost a finger or more. Sometimes I wonder who was a bigger dolt, him for his actions or me for sticking it out.
    I was hoping to use the full length of track which is four feet if memory serves me well. Of that length you lose 3-4 inches from both ends for car control blocks and cam cleats, but, that still leaves quite a bit of travel for a 26 foot boat with a 11(plus) foot boom. Between the halyard, cunningham, boom vang, out haul and traveler...oh yeah, mainsheet there should be enough sail shape control to pass the time getting from point A to point Z.
    I did some rough drawing on one of the profile diagrams found in the Assoc. manual and a coaming that stretches all the way back and around the lazzarette hatch doesn't look bad at all to my eye. The lines coming off of the forward cabin 'shoot' back to a point just above the stern. This 3-day weekend will hopefully afford me enough time to pattern a full scale mock up of the perimeter dimensions. Then we can really see the difference between paper and plastic.
    Have a good Labor Day all.
  8. #278
    I think ebb is incorporating the more ergonomic non-horizontal coamings.
    There is probably an ideal % for the most comfortable recline
    Hinckley DS42
    Ah wood luv to circumslide mah butt around that teak rail from pote to stahbrid... one cool and dewy mornin.
    The more I've dwelled on what to keep and what to change, the more I feel our straight coamings are salient features that can't be messed with without a fight.
    Straight sheer, straight brown "take off" coaming lines. Straight boot stripe, straight loose foot boom. All play in the sweetness of the Alberg design.
    It's getting harder for me to mess with the guy's harmony. I've come to realize that a stripped down virgin Commander with those tall mahogany coamings is unparalled.
    There isn't a mo'bucks Hesperian with a hot-tub cockpit can touch that rare and timeless style!
  10. #280
    All you'd really have to do is...
    Geez! Something as simple as making a form for these coamings is surprisingly difficult! I can't find a line that goes behind the lazzarette hatch that looks smooth. Trying to mimic a CD36 coaming just doesn't fit on our deck (go figure!). The CD 330 and 36 have much wider decks back by the cocokpit and accomodate the wide sweep of the coaming right around and behind. Ours are a bit too...pinched? If you bring the aft portion of the coaming right through the middle of the lazzarette hatch, however, it looks pretty good. Sooo, the new thought is incorporating the aft section right into the lazzarette hatch... Then I thought, do I want a smaller hatch in the lazarette hatch or should I split it down the center line making it a left or right or both type of hatch? This is starting to seem like a lot of work just to reduce maintenance. Especially when you consider I'm adding mahogany toerails and rubrails.
  11. #281
    Lightbulb Hollow coamings and a cockpit remo
    Tony,
    It sounds like you are serious about a fiberglass coaming?
    Just surfed by an aluminum Dudley Dix in the making. The angle of coachroof sides is carried aft in a clean sweep to a 2 step transom. That angle visually becomes a very important part of his design - like a facet of a crystal.
    The Dix is wide enough so that the cockpit coaming does not have to bump out like ours has to.
    Still, a hollow coaming on the Ariel could be made using the seat-back and the coach-roof ANGLES with a nice sculpted curve out from the coach corner. Have to sacrifice some sidedeck to take the wide footprint of this style of coaming.
    (Maybe worth a mock up. I'm using office supply illustration board. It's about 1/16" cardboard, stiff, excellent for nice long curves. But also if its sponged with warm water and bent over a form, it'll dry into a more radical curve. And you can almost get a form to use as a mold if you double up and Titebond bent cardboard forms together to get nearly 1/8" thickness.)
    It might be possible to get a 3" or 4" top flat across the angled panels that could be capped with wider mahogany for sheet winches and for sitting on occasionally. In CPete's post #276, the 'Nahma' illustrates what I'm trying to say. The sweep out from the coach-roof corners.... the coaming is obviously hollow and is capped. On the Ariel, to get some back support, the coamings would have to be taller and therefor the footprint wider, robbing the sidedeck. Anyway I think the angles are important to have it look like Alberg (or Dix) had a hand in it!
    Fiberglass.
    I would lay it up over a male foam (or press-board, or cardboard) mold because there are fewer steps that way - tho the finish is harder to get than if you did it in a female mold (which imco is even more of a pita).
    OR... maybe a veneer of mahogany could be glued on both inside and outside to finish. With a nice cap nobody would know. And areas of the hollow inside could be useful for storage if you dared cut holes in the coaming/seat back. Eh! Hell, whynot?
    Really don't have to go with the curves that fiberglass skin can do. All round single plank coamings with cockpit corners cut from laminated blocks can make bodacious curves too. They be 'posts' front and back like the ones against the coach. You do see coamings sometimes where the posts have been bandsawed with an inside curve too.
    Whatever we do with fiberglass is going to end up heavy. 1/8" to 3/16" frp in a hollow coaming of any height is a lot of square feet. The ole Mahogany coaming is relatively lite. But if you want a three D coaming that is hollow inside why not Dudley Dix and use aluminum sheet??? It'll paint up like the rest of the Ariel - and be even less weighty.
    What would we do without CommandoPete's always right-on pictures? Eh!
    __________________________________________________ ____________________________________
    H m m m m....
    How crazy do you want to imagine?
    If you have an inside diesel planned, that may mean you don't need the lazarette in its present form. So, Imagine the cockpit seats going across the back BEHIND THE TILLER. It could be a lot like one of the two boats in your post 271. Then you might mold in those nice radiused corners you like so much.
    'Course then you end up with a similar problem to mine: where does your mainsheet traveler go??? (My answer is: to hell with the traveler! and go back to the double deck blocks the Ariel originally had...)
    You'd have a longer cockpit apparent. You'd even have storage in the thwart seat locker for an anchor and a bunch of other stuff!
    And all the Commanders in the fleet would finally have Ariel envy!!!
  12. #282
    We are trying ever so hard to incorporate angles, curves and lines allready present in Dream Weaver's original design as to keep the remod as remeinescent of Alberg as possible. Hopefully in the end we will not only benefit from the well founded design of a great naval architect but also have a boat that doesn't look too ugly because of all the changes.
    The current idea is a coaming that provides good support for the back, has additional storage available for lines and such and can hold a butt cheek or two. There are a couple of designs out there I gravitate back to-Cape dorys, the newer Hinckleys, Alereons, Cabo Ricos, Great Dane-you get the picture. The hitch is the 'hatch'. The best looking spot for the aft wrap appears to be athwartship midway through the lazarette hatch. So I'm thinkin new hatch that is even with the top of the traveler track on the inside of the coaming aft and deck level outside of the caoming. That way when on the hook one could slide the boom and traveler over to one side and cozy up in a nice curved aft corner.
    Also been giving serious thought to splitting the hatch into two just to the side of the centerline, incorporate some overlaps for strength and added seal surface. That way one could get in the lazarette without having to open the entire area. Its starting to get more complex than I'm looking for though. We are getting snow today so I'll have plenty of time to think about this one
  13. #283
    Tony, with all that business going on in the aft of your cockpit, maybe you should reconsider mid-boom sheeting and move the traveler to the coach roof and away from the bottoms trying to find a cozy spot? It might make getting at your engine a bit easier too.
    Also, I think Admin Bill should give you a demerit for mentioning that 4-letter s-word.
    Midboom sheeting
    If you are going to cruise the Ariel, you'll probably raise the boom so you can move freely in the cockpit without loosing your head.
    Midboom on the Ariel is exactly over the bridgedeck. If you are going to dodger it, you will probably make that tall enough to get in and out without fuss.
    Instead of putting the traveler way forward over the hatch where the forces are probably tripled to control the boom, I think the traveler could be designed to go over the cockpit end of the dodger. In such a way that fingers are protected. A hard dodger can be designed to help take the forces of a traveler. The block spread on the boom would be further aft, easier to haul, and probably have shorter tails. The almost flat top dodger design that Tony has designed would be PERFECT!
    You may still have to have a new boom made, especially if a rigid vang is rigged along with the extra blocks. Traveler lines would probably stay at the forward end of the cockpit rather than draped over the tiller and tangled under foot like most have.
    An independent arch for the traveler over the dodger could also be used for the forward end to fly a bimini or rig a snug tent.
    __________________________________________________ ________________________________________
    When I asked Sponberg (Yacht Design Inc.) what he would do about headroom in L.G.'s cockpit, he simply raised the end of the boom leaving the gooseneck in its original position on the mast! That's how it's gonna be on Little Gull.
  15. #285
    ...he raised the end of the boom leaving the gooseneck in its original position on the mast. That's how it's gonna be on Little Gull.
    Why? To retain more sail area by keeping the forward end low? Is that a better shape for a loose footed main? Inquiring minds would like to know.
    The hard dodger location seems like a winner, or, probably been mentioned somewhere here, how about incorporating a traveler and a boom crutch?
