Results 1 to 15 of 50
Thread: Headsails
    Deck sweeper reef?
    I'll take what Ed says about sailing as the god's own truth. Everyskipper wants his boat to sail as fast and efficiently as possible. If deck sweepers are more efficient and speedy sails then I'm listening. Soon Little Gull will have to get her new suit of sails.
    Mainly, the reason for high clew staysails is for vision forward, right?. Especially shorthanded, the ability to see where you're going is comforting.
    Is it possible to 'scandalize' a staysail by reefing the clew? That is, reducing the decksweeping action of the sail by folding or rolling the sail UP to a higher clew point?
    And conversely, after leaving crowded waters, the clew could be shaken out and the sail returned to its more effective shape.
    Has this been done? Does the sail need to be cut differently, or can this actually be done casually? Be nice to have the option.
    Why not just a large window?
    Santa Cruz
    I have to say ebb some times your come up with some “very” different ideas. I suppose you can trim a sail any way you want to. I mean there are people sailing around today being pulled by kites. Efficient - who knows? Fun – Hell Yea!
    I have not seen anyone reef a jib as you described. Given the sheet angle I don’t know if the deck is long enough to trim the sail. Throw in a long pendant for the tack and you have one more thing that is going to get fouled (Murphy). But what the heck lets try it.
    All that said, I don’t want to leave the impression that a high clew sail is less efficient. It is just not the sail I want to use under normal SF conditions. But with wind under 20 and a little calmer water, than our bay during an ebb, the high clew sail is very versatile in my opinion. High clew gives you options that a sweeper doesn’t.
    And thank you for the vote of confidence………ed
    Thanks for entertaining the novice, guys.
    Can see, by simply looking at Keith's diagram that the larger the sail the lower the clew - because it is a simple matter of running out of deck for proper sheeting. Really would be clewless for longfoot sails.
    Our 'working jib' seems to be the best all round foresail of the regular low tack sails. With a 110 coming in as a close second. (the 110 is not diagramed on the visual, but I would assume a slightly lower clew.) Correct?
    Light air sails, which are the big ones, are not working per se but are speed sails. Not exactly, I can see that a NO.1 would be very useful for getting a boat back home in failing wind. Keeping the boat at "running man" speed at all times is what the foresail selection is about.
    It is possible that the light air NO. 1, NO. 2 and Drifter COULD have a reef along the bottom of the sail much like the main. In effect shortening the sail considerably. They could then be raised or lowered with the halyard for positioning. Of course that is probably a useless exercise.
    [We did have a lively 76 post 'Roller Furler' discussion in the past. I don't mean to bring that up again]
    Non racing A/C's would more than likely have a furler. (High tack, and perhaps this is why you don't race with furlers?)
    My wish for this gear would be that it would let the sail out and hold it in a working jib or 110 position with a perfect set. In other words the furler would be designed for the half furled position. We have had this discussion before and I understand that foresail reefers do not exist.
    The furler would also unfurl out to a NO. 2 where the shape is more casual let's say. And of course, furl it up totally.
    Could this gear be designed to hold at working jib position with a perfect foil?
    (Will say that I'm disappointed that a no-aluminum foil foresail reefing system has yet to be invented, except for the screecher. These flyers are not able to take air-foil shape like the into-the-wind working jib. I'm a forward lowering mast guy. Can't we have a working-jib screecher? Scoocher?
    I really think a clean wire forestay is the best of all worlds!)
    Can furlers be used for class racing? Why not?
    Santa Cruz
    The A/C class jib is a very good sail. I think you would enjoy your 110 a little more. When we go out we fly a 120 almost always. I think it is Capt Pete who has the praise for a 150 and a reef. With our 120 jib we can take on just about any conditions we find and be very comfortable. A 120 and a reef is an easy sail in 20 – 30 knts.
    Can a headsail have a reef along the foot?
    You bet. In fact I would say that is the preferred way. By shorting the sail you achieve the best of all conditions. The sail chord is maintained, allowing you to maintain shape, and the construction of the sail is still effective. The heavier loads are still where the cloth is the strongest. Here is a link that had a bit of a discussion on it.
    http://www.sailnet.com/forums/seaman...eefpoints.html
    And just for the heck of it here is a link that talks about sail shape, cut and trim.
    http://www.wb-sails.fi/news/98_11_PerfectShape/Main.htm
    A lot of the stuff I read has to do with performance but I think in understanding the fine points of performance sailing it makes one a better all around sailor. Setting a boat up to race is setting it up to sail efficiently. Plus while we are not racing anymore you never know when someone may take a snap shot of you I post it on this board.
    Sure they can. In fact in some classes that is all they use. I worked on an Antrim 27 for three years and all we had was a class jib and a roller. There are a number of classes that do that. But I agree with you “I really think a clean wire forestay is the best of all worlds!”
    Sep 2002
    Southern Maryland
    Not sure I understand your question, so let me play out two possibilities:
    1. It is possible to attach the jib sheets to a higher clew position, but leave the tack alone? My guess is that the sail shape would suffer, and not only that, but the loads on the sail would tend to stretch it across the bias, not how the stretch was intended. (PS, I got "Sailrites" manual of jib sail design and construction----> VERY Good even if you don't plan on building a sail. It goes through where to put shape into a sail, how and why, then shows you how to align the fabric to achieve minimum stretch. ever notice how all hte panels are perpendicular to the leech.... "to achieve minimum stretch" is why)
    2. is it possible to have a set of reef points on a jib just like on a mainsail. YES! I even inherited a sail that looks like this. There is a second Tack and Second Clew a few feet up from the regular clew and tack. This requires you to lower the halyard just like a mainsail. good because you can keep a sail up and still reef (no need to go bareheaded). Not as good because likely the sail is too full for the conditions that require you to reef. But good as a first reefing step.
    -Keith
    ps, glad to see my spreadsheet going to use. You can hide "extraneous" sails on the graph by just plugging in "0" for the luff, leech, and foot.
    -km
    aka, "sell out"
    S/V Beyond the Sea
    C&C 35 mkIII
    Catalina 25 tall rig head sail
    I just Acquired a new roller furling headsail cut for a Catalina 25 tall rig:
    Luff= 30'
    leech= 28.4'
    Foot= 16.9'
    The dimensions are nearly identical to the Commander's #1 genoa;
    luff = 30'6"
    leech= 30'3"
    Foot= 17'
    The shorter luff allows for the luff lost to the furling unit and the shorter leech brings the clew up to where you do not need to move your block when under shortened sail
    The sheeting angle is perfect and the boat sails very well under it. Visibility is also excellent with the raised clew.
  1. "revival" for sale
    By frank durant in forum General/Off-Topic
    Last Post: 05-11-2006, 06:06 PM
  2. Roller Furler
    Last Post: 10-14-2005, 06:17 PM
