Results 1 to 15 of 21
Thread: MILES OF MASKING TAPE
Threaded View
  1. #19
    semco sealer / no tape miles
    Early morning coffee time.
    Nosed around on the net Scott Galloway's TIP on Semco Sealer, usually associated with teak, but works just fine on our teak alternative mahogany.
    Definitely not a varnish-look alternative. What the effect is, according to the dozens of teak furniture manufacturers who recommed it, is a bare wood look. Haven't actually seen a Semco finished coaming, but I've seen a lot of failing and blotchy varnish jobs.
    If it is a careful but simple procedure to reapply the sealer WITHOUT TAPE, as Scott does it, then that convinces me. Tape would not be much help with a runny product - varnish, you could say, is more likely to stay where you lay it on because it has more body. Less likely to get under the tape.
    One hand with the 'applicator', the other with an absorbant rag, could be something I could learn to do.
    The great thing about Semco (taken from the net) is that it is a family owned business. Has been doing this sealing business for 30 years by word of mouth, without advertising. Pricewise a quart costs the same as a similar product from Interbucks or Sherman Bill or Dow/Dupont or whatever Con Glomerate. Sealer gets more coverage, and you don't have to put 17 coats on!
    The little Monk 24' Woodie that was reborn in the yard - that used 3-coat Detco Crystal - it's still going strong waiting for its owner to come get it. Been a year. So there is a 'varnish' job that's lasted...one year for sure... in the California sun.
    Too much bad times with the glitz. I'll go with the mom-and-pop Semco to keep the grey away. She'll never know.
    What isn't clear in Scott's post is why he uses OIL on his cabin sole. Why not the S. Sealer? One less can in the locker.
