I've just gotta get back into boat work to save my soul. So we're starting with 'baby steps' and what better stride than a vacuum bagger? Mind you, I haven't even thrown the switch on this thing yet but it should work. I mean, it's not my brain child. All I did was copy one of Colin Cox's system found on his web site www.buildinggalene.com.
Anyway, Ebb once asked to see my vacuum bagging system and it didn't even exist at that time. So just to keep things right we assembled one. It's venturi operated, controled by a vacuum switch and a solenoid valve.
First on deck are new rails for a sea hood. Yah. The original design I toiled on for countless hours is not going to make the cut. More looking and research and Ebb has driven me to a higher standard. Redesigned side deck scuppers, winch islands and of course the hard dodger and bulworks. But here's the new idea...I call it Inspira'd la C Pete! I'm thinking self-draining, insulated, molded into the cockpit seat DRINK HOLDERS!!
wow over kill. I haven't done that much, but I havent run into a situation where the vacuum needed to be regulated, the leaks in the bag kept is from crushing the core in my past foam projects and if the vacuum did exceed your Comfort range for the material your working with poke the bag, and most of the mechanical pumps are rated 100% duty cycle.
You know, Pete, I read that post three times before I noticed the one tucked in the winch handle holder. I guess I was more concerned about the beer that looks to be seriously close to peril
To make a short story long...I'm not a morning person at heart. As a matter of fact I have a real tough time getting to bed before 1:00-1:30a.m.. But in order to get any work done on my 'love' I hit the shop door by 5:00 BIG cup of java in hand.
We made a template of the cabin top and tranfered that to some plywood stringers and made a (?) form to vacuum bag a hard dodger off of. I think yu can see the lines that we're patterning the top to. The curves came from the port frames that way we have some continuity. The areas with the handles cut in will be cored with wood as will the attachment points. The rest will be cored with foam.
Googled a set of instructions on building a hot wire foam cutter and I couldn't just let it go to waste! We started with a 1/2" platform of Baltic Birch that gets epoxy coated (X2). The base of the island gets 'pulled' over the ply and a styrofoam mold. Once the epoxy cures we can remove the styro and put in reinforcement and attachment points.
I don't know why I like them so much but I truely do covet winch islands
I keep running across these lovely S & S designs with what I imagine are salons NOT saloons coated in raised panels. And who wouldn't love a Cherubini 44 or 48? But who can afford a shaper and expensive bits.
I knew there had to be an easy way to cheat at it. Here it is...
Hey Tony, Whatz the cheat?
Looks like you might be grooving for a slip in ply panel???
Nice handle!
On the winch islands:
I got non selftailers so a set up that would allow a jam cleat on the island is desirable.
But I wonder if the cleat should be AFT OR FORWARD OF THE WINCH?
Talking a non-race set up.
Be great to see an actual successful working set up. Does the cleat need to be on a plate and/or be set at an angle to be able to take the line off and on easy? Should it be a jam or a clam? The more windes on the winch the more a fair lead to the cleat is needed.
I had a hell of a time with selftailers, could never get the hang of it, the tailer part was always too short and the tailcatch too small for my big hands. I'm thinking a longer lead to the cleat would make it easier and really less dangerous to hold and let go of a main full of heavy air???
It is the lead OFF the cleat that I want to get correct. Want it to slip off and not hang up! When the wind's up and the boat's tacking.
I'm assuming the styrofoam is to act as a form for laying up fiberglass to make a hollow form? The hollow form will have a piece of mahog or teak on the top?
