hehe. Actually the boat was rewired prior to purchase so that department is all set, he did however come in handy when I emptied the keel void...
My new bronze port came in. The locations are approximate as I work out the fine details, but here is a preview of what's to come.
Cockpit view (I like these ports because they are almost flush so if you lean against the bulkhead it comfy)
Interior view. I coughed up a couple more bucks for the bronze interior finish ring. It will match nicely with my "someday ports" which will be 12" opening bronze beauties to replace the windows.
The fit is perfect as planned!
A-24 is slowly but surely gaining back her integrity.
My surprising find last week, to me at least, was indeed a propeller aperture filler as Bill suggested. The filler is hollow with an opening in the top and bottom. When I tapped the filler with the handle of a screwdriver it was definitely thin and hollow. I duct taped the nozzle to my shop vac up to one of the holes to suck out any debris or water that might have been hanging out in there. Nothing came out, but I could here a whistle noise so I knew air could somehow get into the void inside the filler. The air was soming in from the other hole. This void would have definitely filled up with water every time the boat was in the water. The apperture is tabbed on with a layer of fiberglass. THe ends were beginning to delaminate a little bit. I grinded off these ends until there was only saturated laminate left. I sanded and prepped the area then coated it with thickened epoxy. I forced some epoxy into the holes so they are now sealed. After the epoxy cures overnight, I'll put a fairing coat of thickened epoxy over that, then sand again. I'll post some pictures of the area coated with epoxy tomorrow after I fair it.
I dremmeled out the dry laminate found underneath the fiberglass rudder tube using a flap wheel attachment. In very localized spots there was some discoloration of the laminate which indicated to me that water had penetrated. I took a fine grinding attchment and drilled out these area like a dentist. Once all of the discolored areas were removed it was ready for a gooping of thickened epoxy.
You can see the areas that were dark after grinding with the dremel. I forgot to take a picture after I drilled out these areas.
Here is the finished rudder tube. It is flush from the bottom of the tube to the opening of the hole all the way around. I'm not sure if this area ever leaked, but no there's not a chance.
Pardon the spider colony part way up the tube.
I sanded smooth the initial coating of thickened epoxy over the propeller apperture. I applied a final coat this morning. This should completely seal the area so that no water can migrate.
Here is the view after the final fairing coat of epoxy cured and was sanded smooth. The area is now completely covered with epoxy so it should stay dry. Paint was applied yesterday. My launch date is tentatively scheduled for June 9th.
Finished product.
