Page 14 of 14 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14
Results 196 to 199 of 199
Thread: Deck Delamination / Core Problems
  1. #196
    Hey 3rdman,
    FWIW, I'd go with MikeG's 40+ years experience and use a foam core. My side decks are plenty stiff with the Corecell.
    Agreed: properly mounted hardware etc. will keep the core dry, BUT, it's hard, nigh impossible to keep all water out 100% of the time. No telling where it'll come in, mounted hardware, port light frames, a hastily drilled fastener... It's nice knowing that no matter how badly I mount/seal my hardware, the deck core will NEVER rot again.
    As to scarfing, my 2 cents. Cutting the skins first is the way to go. A lot of mine were still adhered to the core, and it would have been impossible to separate them without breaking had they been pre-scarfed. Also, a clean cut line gives you a nice reference for doing the nasty grinding for the scarf joints after the skins have been glued back on.
    Doh! Capt Ebb's reply just came in. Hope I don't contradict his wisdom...
    PS. Then there's Craig's post above - I'd like to have seen pics and have more detailed info on his POs recore/repair. All sorts of opinions out there...
    Mar 2006
    Havre de Grace, MD
    Ebb & Mbd,
    Thanks the balsa is in route, the price was too good to pass up, I'll make sure I designate a photographer for "in progress" pics, even if its the seven year old swabby. As for epoxy, I'm likely getting the epoxyproducts premium no blush.
    I'll keep ya posted.
    #97 "Absum!"
  3. #198
    Corecell Core
    Just to revisit this thread, here is what a section of deck looks like with a Corecell core.
    M'sieur, I'd like a half dozen of those with a little dijon
    and a bottle of your finest grand cru red.
    By Theis in forum Technical
  2. Deck hardware plan, and
    By c_amos in forum Technical
  3. Cockpit Delamination / Core Problems
    By tha3rdman in forum Technical
    Last Post: 04-06-2006, 09:02 AM
  4. Replies: 11
