don't know much about epoxy
don't know much about sanity ...
Peter. 338 is mostly nude inside, just couldn't stand the funky cover-all-yer-sins spraypaint job especially that splatter paint with pastel color droplets in the cabin. SO WE GROUND IT ALL OFF. Up inside the toe rail too. (and under the cockpit)
You paint on your regular 2:1 epoxy. {been using TAP which doesn't blush even when slow curing). Wait til it gets tacky, your finger doesn't get wet, press on the fabric, it will cling nicely. Finish off with a fresh batch with silica so it doesn't run. Fabric WILL go clear and it ends up smooth too using vigorous bristle brush and latex covered finger. A plus: using the thixotropic silica allows you to push the goop into the weave after it's set up where the cloth spanned what you didn'i grind smooth in prep, you can end up with no obvious voids.
