Ebb -
I ***love*** the openness. Before, this boat didn't seem any bigger than my old Com-Pac 23. Now, I know it is, and it feels "freer". It also seems a little cooler - I think that air is circulating better, being wide open like this.
Funny you should mention an exterior deck beam. When I was gazing at the underside of the strongback-less deck for the first time, I started giving thought to that space between the inner and outer deck skin...
Could be that it would be possible to remove the outer skin and coring in a wide configuration like I've been thinking, and replace it with something structurally stronger. If that structure could spread load across the cabin trunk top out to the sides, and was supported on the underside by the vertical poles, it would work nicely, and I don't think would have to be very visually noticeable at all from the exterior. On the inside, you could have an unbroken span. It would be pretty easy to bed a metal plate between many layers of glass inside that space. If, as you propose, that metal plate wrapped around and conformed to the whole cabin top shape, and was thick enough for the stresses, it might not even need any interior support. Bliss!
Hmmm... Gad, you got me started again...
Re: cubics and related such:
Moisture and mold: I don't think it will be much of a problem. Why? Because these are relatively small boats. There just _aren't_ any lockers which remain closed long enough for it to develop to any appreciable degree. I've found that I am constantly diving into every storage bin I have, because I only have aboard that which I *need*. Maybe on a larger boat lockers sit unopened long enough for mildew to be an issue, because you have places to put infrequently used "stuff" and forget about it, but I haven't found that to be the case on this boat or my last one. Even if I don't use something much, it still gets regular exposure to fresh air because it sits near something which I do use on a regular basis, and so its locker gets ventilated. Keep in mind that where I am, we have 6+ months of the year with temps regularly exceeding 80*, and humidity rarely drops below 70% - prime mildew country, and it just hasn't been a problem at all. The only place I've seen mildew develop is on the inside of the hull. The lockers will be finished with a slick surface on the inside, to make cleanup the matter of a few simple wipes.
Flotation: I'm picking it up wherever I can.
Right now, for this temporary structure of compartments, I am using scrap plywood I have gathered up (recycling), but for the end product, I'll be using sheet foam instead. I'm leaning towards polyurethane foam and polyester resins, not epoxy, mostly because of price, and also because of ease-of-use (i'm very familiar with PU/PE construction). For the cabinet structures, they'll be a slab of foam skinned with glass, cut and used just like plywood, after they've cured hard (laid up outside of boat). For install, the side which faces into the boat may get a layer of formica or luan for impact resistance. Just the structure of the compartments I will be building in, made in this manner, will net several cubic feet of positive flotation, and be lighter than wood to boot.
I'll be stuffing glassed-over foam into all odd and difficult to reach places. I've been wanting to insulate the hull anyway, so I plan to put 2" of foam up against the hull throughout the interior of the boat - this will bring the inner wall of the hull level with the stringer which runs along it, and will give 8+ cubic feet of flotation by itself. I think I can get 10-15cu/ft into the cockpit lockers and under-cockpit area. I'm going to use bladders for water tanks, I may lay them into compartments where all the extra space around the bladder is foamed. The storage compartments up in the v-berth will give about 25 cu/ft of closed space. In the end, the closed-off and foamed spaces will total more than 65 cu/ft, because some of them will be partially filled with heavier-than-water substances.
The individual compartment lids will sit on gasketed lips, with pre-drilled holes for watertightly securing them to the compartment. All these holes will be the same size, so that they'll use the same size fasteners. Fasteners and a manual tool to put them in place quickly will be stowed handy in case they are needed, so that completely closing off a compartment where water is coming in can be done with minimal fuss. At sea, the compartments will stay closed, partly fastened already - not too hard to access if needed, easy to secure against ingress. I can pull out several days worth of stores, to be stowed in an easy-access compartment, every few days/as needed - kind of like "reefing early".![]()
