http://cgi.ebay.com/ebaymotors/ws/eB...tem=4647290518
The Pearson Commander is a 26' daysailer/overnighter/weekender designed by noted Naval Architect Carl Alberg. Carl Alberg designed many classic sailboats, including: Pearson Triton, Pearson Ensign, Cape Dory Typhoon, and Alberg 30. Alberg designed boats with full keels, narrow beams and classic looks. And his designs were known for their seaworthiness and well-mannered sailing characteristics. (One Commander was sailed all over the world, and Carl Alberg himself also owned and sailed a Commander.)
The Pearson Commander was produced by Pearson Yachts from the early- to late-1960s, and it is the sistership to the Pearson Ariel (which was also produced during that time). The Commander and Ariel shared the same hull, but the Ariel was orientated more to cruising, with a larger cabin and smaller cockpit, while the Commander emphasized a much bigger cockpit and relatively smaller cabin. In fact the Commander's 9' cockpit is one of its best features because it provides ample room for comfortable daysailing. While basic, the cabin has overnight accommodations for up to 4 people, space for a head (under the v-berth), and a galley sink. The Commander can be viewed as a bigger version of the Pearson Ensign, another classic Alberg design.
This Pearson Commander is a 1964 model and is Hull #5 (yes...Hull #5). It might be the earliest Commander currently in existence. Additionally, it was owned by one family continuously from initial purchase until it was donated to our sailing organization.
This Commander comes with mainsail, genoa, jib, spinnaker and full mooring cover. Auxiliary power is provided by a 7.5 hp Johnson outboard. But it is a vintage boat and is in need of some work. (See "Vehicle Condition" below.)
Pearson boats have a strong ownership communities and the Commander is no exception. More info on Pearson Yachts, Carl Alberg and the Commander is available on the web at:
http://www.pearsonvanguard.homestead...es/comandr.htm
http://pearsoninfo.net/commander/commander.htm
http://www.bway.net/~bogle/commander.html
http://www.alberg30.org/collaborate/PearsonCommander
Additionally, a Google search will probably turn up other sites of interest.
This Vessel was a donation to Planet Hope (www.planethopedc.com), a non-profit organization, to benefit our sailing programs for at-risk youth. It will sold to the highest bidder without reserve.
SPECIFICATIONS
Year: 1964
LOA: 25' 6"
LWL: 18' 5"
Beam: 9'
Draft: 3' 8"
Displacement: 5,100 lbs.
Ballast: 2.700 lbs.
EQUIPMENT
Sails and Rigging:
Mainsail
Genoa
Working Jib
Spinnaker
Spinnaker Pole
Cockpit Winches
Mainsail Winch
Traveller
Standing Rigging
Interior:
V-Berth
Port Berth
Starboard Berth
Head Area under V-Berth
Pump Sink
Folding Table
Full Cushions
Other Equipment:
Johnson 7.5 hp Outboard
Outboard Motor Mount
Mooring Cover
Bow Pulpit
VEHICLE CONDITION
This Pearson Commander actively sailed the Chesapeake Bay for many years and often competed in local races. As mentioned before, she was owned by the same man and his family until her donation to Planet Hope. She has been stored on-land for many years and is now in need of some restoration work.
The hull and bottom look to be in decent condition but she needs new bottom paint. You could opt to paint the hull. Three of the four sails (mainsail, jib and spinnaker) are in good condition and the fourth (genoa) is in average condition. The standing rigging is intact but she will need new running lines. The interior cabin is also intact. The Commander was outfitted with a well in the lazarette for the outboard. This boat has an outboard mount on the stern. You could keep the outboard there or put it back into the well. The outboard has been stored indoors. But it has not been run in some time and you should assume it would need maintenance.
There are four main areas of attention:
Foredeck: This boat has soft spots on the foredeck at the bow area. There are also cracks in the deck where the bow pulpit is attached.
Cockpit Coamings and Tiller: The wooden cockpit coamings are intact but have large lateral cracks and should be reinforced and treated. The tiller has completely deteriorated and needs replacement. Additionally, the metal rubrail is loose along the starboard cockpit side and should be reattached.
Cabin: The cabin cushions are dirty and could benefit from new covers. The current covers have some holes. Also, some of the wood access panels on the cabin floor need some support trim reattached.
Cleaning: Lastly, the boat needs to be cleaned. In fact, the boat is dirtier than the pictures show. (I don't know why that is, but it is.)
There are other dings and scratches from usage that may not show up in the pictures. And you would certainly find other things to work on. For example, the running lights, battery wiring, etc.
In conclusion, this is a 1964 Pearson Commander...perhaps the earliest Commander in existence. And it is interesting to note that this boat was owner by the same person from her purchase in 1964 until her donation last year.
She comes with a nice suite of sails, including spinnaker, outboard, and a full mooring cover. But she is in need of work. You could opt to work on her enough to get her back in the water, or go for a restoration. Either way, she deserves someone who can provide good care.
The Pearson Commander is a classic full-keel daysailer/overnighter/weekender from the draft board of Carl Alberg. With a 9' cockpit, she has lots of space yet still has accommodations for overnights. This boat would be suitable for someone who is looking for a classic and who can provide the care and restoration she needs and deserves. If this does describe you, please do not bid.
All pictures are recent and were taken on May 5, 2006 where the boat is presently located. There are also about 70 pictures for your review posted on the internet at:
http://pg.photos.yahoo.com/ph/mhunsicker1/my_photos
