Ebb, The area we're dealing with here is behind the lead ballast. Those holes I drilled are in the aft section of the bilge where it begins to rise from the deepest part.
The stuff in post# 162 is the original foam. It was dry and stuck to the glass pretty good. Initially, I dug rather agressively with my big, busted screwdriver thinking I would be replacing alot more foam filler. Not much of it came loose though. The top hole didn't even commincate with the bottom three. The bottom three shared a space just below the surface of the fiberglass. The biggest hole had a 1/2" crevice that lead downward about 8". After fishing around with some stiff wire I decided it really wasn't as bad as I thought, and, I had better start thinking about repairing the void instead of making it worse.
Yeah, I may have water migrating into the void again, but it won't come from the bilge. One of these fine vessels has a drainplug installed and I'm begining to think that may be the way to handle seepage. Maybe even two plugs so you could force air through to facilitate drying....would the owner of said boat lead me to the link?
