Because of the lack of room and, more importantly, the fact that I only had a 52" stick of teak left, we made a modified dorade box. It will still drain through weap holes but the air will have to go around a baffle. Such is life. I'll deal with it...
What really stinks is my boring bit/countersink and plug cutter are two different sizes. I had enough scrap to cut ten plugs. Plan D
You know Tony, you may have something there! Never seen this design be for - and why won't it work? Unique!
Everyday dorade boxes have one or two baffles across the box to help separate water from the air coming in the cowl. I can't see why Tony's horizontal/slant innovation won't work just as well - if not better!
One of the 'improvements' I've noted in my collection of Other People ideas is the install of two access plates on top of the box. The idea being that in good weather you could move the cowl right over the hole to get direct air flow below.
Another was to put on a lexan top instead of teak to get light thru the opening. Which is to say that maybe your slanted baffle plate could be lexan, or even the top as well? (The second plate over the forward opening might also get more air below with the cowl there!)
Anyway, just my way of expressing enthusiasm for your invention! Way cool!!!
It's already August 12th. That puts me about...uh...mmm....4 or 5 weeks behind schedule. Just spent two week NOT working on the boat tending to other business. I was intending these last two week to be used for letting the paint fully cure. Ha!
I was finally able to get back at this weekend. The v-berth fixins are tabbed in. Biaxial (4"), matting, roving, matting, cloth. That should be pretty similar to the schedule that what was in there to begin with. Anyone find anything different than that?
The port openings have been drilled, threaded, redrilled, and the stainless bolts installed. The bolt holes got some epoxy pushed in, and now have two coats of fairing compound. Several more to go for sure!
Made a White Oak beam that will get glassed into the lazarette (just for you, Whaleshark!) to become the backing plate for the backstay chainplate. If I can get a picture of what's in there now I'll post it. You wouldn't believe it!
It's time to start looking at the hull too. I guess it's a bad time to be opening another store on top of all this. I mean, priorities being as they are, come on, the boat come first.
Actually, I had to get at this thing. It has been bothering me for five years now. After we first got 113 home I noticed we had some leaky deck fittings. That's ok, I thought, we can fix that. Besides, the water always found it's way to the bilge where it should end up. But one time I didn't get back on board for a day or two to 'sop' up the bilge. When I pulled board up the water was gone! A little while later I noticed water pooling by the rudder shoe.
After opening things up this morning I was able to confirm my suspicions. A little grindin', a little fillin', a little glassin'. Top that off with some paint to spiffy things up a bit. Viola! We got ourself a new wine locker
The sole seemed solid as a rock. However, one can see that many a gallon has poured over these soles.
Everything that goes back in will be sealed in two coats of epoxy and painted with bilge kote. Yes, I do intend to have this boat for the rest of my life.
