[size=2]Looks like a first rate fit!
If I had an inboard, (especially the diesel you have that I would dearly love) I think I should look for this same modification.
Tim Lackey certainly has MUCH more experience then I, but there are two issues I did not see addressed in the install that you might want to think about.
The cockpit is a very wet area, it does not just take water with large breaking waves, but every rain that falls. I did not see (maybe you just left it out) any caulking used to seal the hatch to the deck. Water intrusion past the flange will cause you much heartache down the road.
The other issue was the bare core exposed by the sawing. Should moisture find it's way to this, it could soften the entire cockpit floor in short order. A good example of how to deal with this potential problem can be seen in Kurt's installation of a Hawsepipe aboard #422
Again, Tim Lackey (and others on this board like Mike and... ok most of this board) have more experience then I so they may have other suggestions. I think the project is a great addition to the already great boat you have got a hold of.
[/size]
