Would someone please comment on the verbatim quote to follow with regards to our (Ariel) boom. It comes from:
http://www.briontoss.com/education/a.../miscmay04.htm
"3. Reef Clewlines
Most production sailboats have the reef clewline sheaves in the end of the boom. This arrangement is great for manufacturers, as it means they can turn out booms much more quickly than if they installed separate cheek blocks on the boom for the clewlines. But it makes for lousy sail shape. and can even harm the sail, because too much effort goes into hauling the sail aft, and too little into holding it down. To make matters worse, the arrangement allows the reef clew to 'float' up, resulting in line chafe, and to prevent this you have to lash the clew to the boom with a separate line. Sheesh!
So put your deadends directly under where the clew will be at full extension, and put cheekblocks about 6" aft of this, for a much better vector of forces. Lead the lines back to the boom via halyard entrance plates, fixed to holes cut in the boom. We do this "reef upgrade" on a lot of boats, and people are always very glad of the difference it makes."
Would like to hear a general comment, but also if you can explain the sentence beginning, "Lead the lines....." would be internally grateful!
