Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Thread: Cabin Table
    Oct 2009
    New Orleans metro area
    Cabin Table
    I have been contemplating building a cabin table to allow my wife and I a place to eat when anchored or at the marina. I wonder if anyone knows whether Pearson provided a table as an extra accessory and would a appreciate a description or a photo.
    Thanks,
    Marcelo
    I have one that I've not found the need to use yet. Don't know if it was an accessory or if someone made it along the way. If I remember correctly, it attaches to the compression post (Commander) and has an additional support for the aft end - so one person sits port, one starboard on either side of it. Measures roughly 20 x 30". I can take some pictures.
    Oct 2009
    I apologize for not having mentioned that the question pertains to an Ariel which of course does not have the compression post.
    Thanks,
    Marcelo
    A-407
    There's a pic here: http://www.pearsonariel.org/discussi...FS-Ariel-in-VT
    I finally gave in and picked up a table and hardware from a CD 25 that was being parted out. I plan on trying to track down or find a suitable second piece of hardware so I can use it in the cockpit as well.
    Oct 2009
    Mike,
    What holds this table up? Where does it attach to? Is it removable?
    Marcelo
    Adastra (A-407)
    Ah, I knew there was another pic here in the forum. Here's one from A-109: http://www.pearsonariel.org/discussi...3050#post23050
    A slightly different style, but a better pic. Ben set me straight - I didn't know Ariels came with a table option. It appears that perhaps there are at least 2 versions? I wonder if any other forum members have Ariel tables?
    Missing Table
    Manual shows no standard or optional equipment list with a cabin or cockpit table.
    Nor does the plan view of the interior (Ariel page 147 - Commander 149a) show a table or where it would be located for either boat.
    A cabin table would be custom made and highly individual to the needs of the owner.
    There are many styles from utility to mirror varnish. Make a statement, make yer own.
    Ebb, that's what I thought too, but Ben pointed out here: http://www.pearsonariel.org/document/Fact2.htm
    Table option: $55
    table $55
    wall ahl be damned!
    Maybe they are talking bout that little table over the head in the forward stateroom?
    That's a real nice marina table on the blueline post #4.
    Flatish table legs could slip into strap slots on the front of the settee, and be quite sturdy.
    Leave room for one to sit at the table side with one or two on the other settee with the table's folded side up.
    The table top could be made to tilt for adjustment or to fold flat for storage.
    Maybe could hang on the V-berth door?
    A well designed un-teak version cut from a single thin sheet of phenolic marine ply wouldn't have to be a very thick stack - and might be stored behind settee cushions in one or two pieces.
    The traditional small boat challange is to get the table to double duty as the aisle filler between the settees for double bunking!
    Or make it a shorter table, a cocktail size, that two could sit on the same settee with the table between them.
    The kitchen counter could have a pull out, or a fold up - or down - that could also be used as a table of sorts.
    Oct 2009
    Thanks for all the input related to this table. I now get the idea. The original table as seen in A-109 seems to be a nightmare to store.
    It definitely needs to be foldable and practical to store.
    Marcelo
    Mar 2004
    Maple Ave Marina, Bayshore, NY
    ariel table and mast climber
    I have an ariel table in good condition and might be interested in your mast ladder.
    Joe
    jfpezdek at yahoo dot com
    I didn't know Ariels had tables. (??) You don't have pics do you?
    Nov 2009
    Brooklyn, NY
    Here's a picture of Ariel 109# factory listed optional dinette table. Has a hinged teak leg that attaches to a plate in the cabin sole and one end of the top mounts to two metal brackets in the vee berth's door frame. Matching Formica to the boat's other table surfaces, Irish Linen.
    factory table vs shop made table
    HMMMMM, does look a bit large to fit IN the door frame?
    But, that makes me think that you could make a table that fits into the frame like a door.
    Have take-apart hinges that allows the door/table when opened to be lifted off
    and set up - like the table in A109 - but narrower and a bit longer.
    A couple throw-bolts or a separate wooden bar across the cabinets at the doorway - and a foldown leg.
    The body made of varnished Meranti with mahogany trim shaped in a low fid to keep stuff on the table.
    For lightness, the door/table panel can be made with a single piece of 1/4" Meranti (yes!)
    covered with 6oz woven glass in epoxy on both sides. Then, instead of varnish, painted a beige
    color as in A109 and edged with mahogany. Hardly any weight at all!
    One-fer-two........One less loose piece of furniture.
    Mar 2004
    The above picture is the same table I have for my Ariel 214. It is large, heavy and was from the factory. It is wider and shorter than the door. I also have the original door.
    I am having trouble logging into the site. I log in then get a message that you're not logged in and asked to log in again and again. It seems like I am in a loop.
