I need some help finding the drawing of a downhaul to help douse the jib from the cockpit. I have seen it a few times before but I can not find it now. I know that Bosun supply made the sketch. HELP!
All you need is a couple of bullet blocks and some line to DYI , I've rigged dozens of them . You can get fancier if you want and I'll tell you how if you want and it will still be cheaper than a kit .
Check the sail control drawing in the free Harken catalog. The drawings are in the front section.
Checking Harken's catalog, I found that it does not show a jib dousing arrangement. It does have a genoa cunningham setup!
Schaefer’s catalog, I believe, has similar drawings and may have one for jib dousing.
Better yet, take up Mike's offer . . .
This is the link to the Bosun's Supplies diagram:
http://www.bosunsupplies.com/Downhaul.cfm
