Results 1 to 4 of 4
Thread: Urgent: Universal atomic deisel #5411???
    Jul 2014
    Brooklyn, NY
    I have a small window to purchase a UNIVERSAL ATOMIC DEISEL #5411
    Does anyone know if this is compatible with the Ariel without major refitting?
    THANK YOU!
    Ariels were designed with the A-4 as their inboard auxiliary power. If the Atomic Diesel has the same block, etc., it should fit. But, that's just my assumption.
    Apr 2015
    Chicago, IL
    The Atomic 4 and the 5411 use different blocks but are similar in size although not identical. The 5411 is a couple of inches taller. Below are diagrams with dimensions for the two engines.
    Name:  AT 4 Dimensions.jpg
    Name:  5411 Dimensions.JPG
    Jul 2014
    Brooklyn, NY
    Thank you!
