It's a safe bet that physicists and chemists will never figure out if there really is life out there. Human consciousness, that's another mystery. AND why so many and so little of that?
Ole Al was a proponent of time/space relativity. So was Carl, of course.
When next broad reaching (no pun intended) in your Commander or Ariel,
you are moving at about
.00162 knots per second - on a 'pale blue dot' that is rotating at
18 miles per second - whose seasonal circuit of its star is about
20 miles per second - in a solar system moving in its star community about
13 miles per second - which is moving about
200 miles per second in the Milky Way - which is drifting about
100 miles per second in relation to all the other galaxies.
SO, if you feel a little funny - it is not the knishes for lunch -
non-theoretical relativity is the problem.
__________________________________________________ ____________________________________________
Nice boat C'pete!
Notice the aft-lowering tabernackle
and those great hinges on the aft-opening forehatch.
Definitely a European/Brit sailboat. Can anybody ID the beauty?
Looks like about the same dimensions as an A/C,
with a very similar straight sheer and a nice laid deck!
We had a Burns 30 that had an aft-opening forehatch. Felt it improved safety when changing headsails (or otherwise opening the hatch) while sailing off shore. Less ocean below
Really nice 7 page download (print notation at end of article)
Tummler must have been a really high end yacht -
as the multiplier (4.2) for the stated German marks cost of 15,000 into 1929 (pre-crash) dollars puts the value at $63,000.
Now if anybody, accepting that,
wants to put Tummler's 1929 dollar cost into present day
InflatoBucks...........
It all relative, folks.
__________________________________________________ __________________________________________________ _____
Hey there bill,
We posted at the same time.
About that replica idea. I just took my inch rule that also has a mm side to it and laid it along the drawing on page 3 of the downloaded document of the interior - plan and side view.
In mm the actual measure of the image is 11 1/2 mm. If you double that you can translate the scale roughly for feet. (Because doubling 11 1/2 gives you 23.) You are correct - the inside height is only about 4 1/2 feet under the cabin deck. Extra wide, extra long slide hatch might work.
I might first upscale the inside to say Ariel dimensions (5'6"??) and see what upscaling all of Tummler's dimensions would produce; length and beam.
In many respects the Harms/Tummler design from 80 years ago is quite modern. Straight stem. Length to Beam ratio.
I had the same thoughts about the canoe body and straight stem. she could be a fast inshore boat. 'would probably even get someone an invite to a classic (wood) yacht regatta.
