Results 1 to 15 of 17
Thread: How tough IS the bottom of our keel?
    RE: Just how tuff is the hull of an A/C?
    Frank, A frp sailboat should gradually get thicker from the sheer on down. 338 is not much more than 1/8" at the seam. But seemingly only getting to 3/8" down in the keel. That is what is so disconcerting, 338 seems to be very conservatively layered, if you can call it that. Even the transom is barely 5/16 in the center, fattening out in the corners and the tabbing across the top.
    The hull/deck seam is thickened by the mat tabbing. (On 338 the toerail molding is now filled flush to the inside of the deck.) A test hole thru the topside in a chainplate area yeilded 3/16"
    There is considerable factory tabbing of the cabin decks, bulkheads, settees, stringers, although the tabs seldom go further than 4-5" from a joint, which may accouint for varying thicknesses of the hull in proximity. The old cockpit drain holes showed the hull to be around 3/8s.
    I feel a little better that the keel cavity is filled with epoxy and there is now a built-in watertite tank running the length of the cabin over the ballast in the turn of the bilge. 338's (supposedly) lightly built hull will have all its furniture tabbed in and probably a layer of 20oz xmatt (about 1/16" thickness) most areas below the waterline. Insurance???
    Maybe somebody knows just how hard or sharp coral calcium is? Probably harder and sharper in the tropics! What will it do to the hull of an A/C? Has anybody seriously run onto rocks? What damage occured? Pictures? More than curious, would like to hear and see what the A/C hull can take!!!
    Apr 2002
    Houston, Texas
    My dad was initiated into the "I grounded her" club in the late 70's off of Johnson Island near Marblehead in Lake Erie. Wacked our Ariel really hard on a limestone boulder. Minimal damage to the keel, but the rudder was another matter.
    Kent
    Nov 2001
    Going aground is part of a day's work, and the Ariel takes it well. On the St. Mary's River going into Lake Superior we went aground at full speed on an uncharted rock (granite up there, none of this soft limestone or coral) hard enough to send my wife to the hospital (she doesn't sail any more for some reason).
    I don't run aground intentionally, but because of the Ariel keel, and the way the boat is built, I take her places others, with their fin keels and spade rudders, wouldn't dare go. Just, when you touch, try to touch softly, when there are no seas.
    But I do have to recount the story of when #82 was pulled off the beach by the Coast Guard, after been pushed up there by a passing ferry, and the Coast Guard whatever said "Any boat that has been grounded should be put into the dumpster" So here I am 30 years later. But I can empathiize with your reaction
    Don't worry about it. It doesn't make any differenc anyway if the keel fills up with water - unless you are a racer and don' t want the extra weight. And if you have a hole in the keel shell, that will drain the water automatically when the boat is pulled for the winter.
    Thoughts on grounding
    [size=3]This morning I as was re-reading Kurt's account of bringing Katie Marie home, [/size][size=3]I came across the following excerpt;[/size]
    [size=3]"Now, some folks have a strong aversion to running aground. I do too, when circumstances warrant it, but I'm not scared of boat-touching-dirt when there is nothing to be scared of. My only concern was large wakes, but there was very little traffic this day, so I felt we would be alright, and soon Katie would float again, swinging head to anchor and wind, probably in 20-30 minutes. I probably could have backed off under engine power; I'd been half expecting to polish the keel on the bar anyway, and so had been moving at a drift when we got upon it. However, being a relative professional at this style of intentional grounding has its merits, and I think I could even describe it as a "technique", if forced to take a position on it by some argumentative boating types. Different strokes for different folks, and all that. Anyway, it served the purpose, and in about 25 minutes I felt Katie lift and start to turn into the wind, a floating boat again. I was halfway through getting ready for the next leg, so I watched for a few minutes to see that the Fortress, self-proclaimed "Worlds Best Anchor", would hold us steady, and, seeing that it did, continued my tasks."[/size]
    [size=3]Drawn from;[/size]
    Link to Kurt's Log 'Katie Marie comes Home'
    [size=1](An excellent read by the way).[/size]
    [size=3]As a fellow 'relative professional' at running aground, I would dare say that the sand in the New river does a nice job of keeping the bottom of my keel clean.[/size]
    Jun 2002
    Portsmouth, Virginia
    Hull Thickness
    When Mike Goodwin and I removed and filled the through hulls on Commander #105 the hull was more than 1" thick closer to 1 1/2 " and the glass seemed like new. I have run aground hard at full speed and there was no damage to keel, the 6 hp Nissan 4 stroke was able to back out with some little difficulty. Note that my good ol' boat survived having another bigger boat on top of it and crushing waves and all kind of hits from wrecked piers and other boats during hurricain a couple of years ago that sank or severly damaged most newer boats in and around same marinia. This is one very tough old boat, very much heavier then new ones of same length today with such sweet lines too. I will be posting photos soon as I get the mast back on and deck painted.
    Jan 2005
    middle earth
    Exclamation they dont build them the way they used to
    most of the older fiberglass boats of any brand were built stronger than todays boats.at the marina where I was for hurricaine jean last year the marina was totally destroyed.many of the newer most recently built boats were pulled off the bottom in pieces.a brand new catalina 30 was basically split in half by wave action upon a piling.my 1967 islander wayfarer was obviously pounding on a piling by the same wave action yet remarkably remained afloat suffering only major cosmetic damage only
  1. stripping the bottom
    By ebb in forum Technical
    Last Post: 04-01-2008, 12:25 PM
  2. safe bottom paint time
    Last Post: 01-13-2006, 07:55 AM
  3. Holes in my keel, holes in my heart
    By captain crunchie in forum Technical
    Last Post: 04-14-2005, 06:47 AM
  4. copper bottom
    Last Post: 10-08-2004, 03:16 PM
  5. encapsulated ballast
    Last Post: 11-20-2001, 06:05 AM
